Originally posted by E-man This first one is egregiously blown out in TAv. Interesting that the EXIF information shows it as manual. Exposure time was recorded as 2.5 seconds.
I managed to access the originals at photobucket (
HERE). According to the out-of-camera EXIF:
2.5s and f/16 @ ISO 100
Metering mode = "Spot"
EC = +0.7
Mode = TAv
The set exposure was EV
100 6.7 while your description of conditions would be about EV
100 15.*
The result was about 8 stops overexposure. Conclusion: I can't say for sure, but I suspect that the spot meter reading was taken from a bright part of one of the flowers and that the camera lowered the ISO to its basement setting. The metered EV, being still out of the camera's range of available settings would have resulted in the viewfinder and rear LCD blinking (indicates error condition). Under this situation, the shutter button would still work, but the results will reflect the user settings at ISO 100 rather than the metered EV.
Is there a problem with the camera? It is not possible to completely rule out some sort of controller failure since you recall setting a longer shutter speed. I would suggest repeating using multi-segment metering (rather than spot) and taking careful note of the actual settings displayed in the viewfinder for comparison to the values recorded by the camera on review. I don't know if it was doing so for this photo, but if the display is flashing, be prepared for poor exposure.
Originally posted by E-man This one was taken in manual mode this afternoon in overcast conditions
This one looks fine. The exposure settings (1/60s, f/8 @ ISO 800) are appropriate for the scene. Again, spot metering was used and the point metered was probably some of the foliage (an appropriate target).
Originally posted by E-man This one was in TAv mode. The camera chose to drop the ISO way down.
Metering (spot again) was on the white flower petal. Given the meter method and target, the exposure (1/160s, f/8 @ ISO 160) is
correct, though not appropriate. Again, I would suggest other than spot metering.
Originally posted by E-man This one was in Program mode. The camera chose a wider f-stop (5.6) than I would have.
That happens...the program line is what it is, though with Pentax, you are able to override using the front and rear e-dials.
Originally posted by E-man This one was in "green" mode. Again, the camera chose a darker exposure value than I would have.
Again, this sort of thing happens. The camera is doing its best to avoid "clipping" (overexposing) the white blossoms.
At this point, my opinion is that there is probably not a problem with the camera. The washed out photo above is what I would expect for what was recorded in the EXIF. That being said, I suggest being aware of shutter settings when applied manually and chimp the settings on review to make sure they are the same until you are confident that the camera is following your directions.
My advice is to avoid spot metering. It is a specialized tool and requires a fairly thorough knowledge of what the meter reads and how to place exposure to the part of the frame metered. In both properly exposed images above, the metered area fortuitously fell on the green foliage. That corresponds nicely to the 18% gray value that the meter is calibrated to and results in an appropriate exposure.
* Exposure Value (EV) is derived from the combination of shutter speed and aperture, qualified by the set ISO. It is the basis for the so-called "sunny 16 rule" and may be used as a way to describe scene luminance. EV
100 6.7 would be a typical home interior while EV
100 15 would be a bright sunny day.
LINK
