Maybe this may help with 'aperature block' (?) maybe fun?
This may sound weird, but I happen to notice that if you gently shake your camera near your ear, you may hear a sound of something sliding back & forth: maybe this is the troubled aperature thing moving. If it moves that would be good; maybe you can do this once in a while to help clean the contact point to lessen failure(?). I've done this sound test on 2 K-50's and both sounded the same. I've done this to a K-3 and no sound. All cams were around 2K shutter count. You don't really shake it, just throw your arm back like throwing a football, with the lens forward and carefully listen (that's the way I did it). I'm not a tech, but thought this would be interesting. thanks
