12-31-2018, 05:38 AM - 1 Like   #166
QuoteOriginally posted by ABel Quote
Hi,
Try to open the debug menu with the contents of this archive.
Please let me know if this helps.
Thanks a lot ABel !
It helped, now Menu items are working fine.
Best regards
01-01-2019, 02:03 AM   #167
A friend of mine had a similar situation with his K50 which he purchased on ebay, it had the usual faulty solenoid and he asked me to repair it for him and if possible to change language settings.
After I changed the solenoid I used the usual debug mode and thus was able to change the region code.
But then I tried to do the firmware update, as soon as the card with the firmware was in, the K50 gave the message: Card not fomatted
I formatted several cards several times, every card was recognized immediately. But as soon as the firmware I tried several versions as well): Same message again.
Same if I tried again debug-mode!
So I downloaded PK_Tether and programmed: Debug mode ON
This was the solution: I could now install the latest firmware, programmed: Debug mode OFF
and now the K50 works fine.
01-02-2019, 04:33 PM - 1 Like   #168
ABel, Many Thanks !!!! Very nice, the former K-30 works very well as a (new) K-50
rrmode
01-03-2019, 01:13 AM   #169
dear all,
Is it possible to read Focus Pulse value (focus stepper motor) using this firmware?
Thank you very much in advance.
Best regards,
suryadi
01-04-2019, 11:07 PM   #170
altopiet's Avatar
Hi there,
I have adapted the latest K-50 firmware version 1.10 to work in K-30 cameras. The initial testing is complete, all test cameras work fine.
The following functionality from K-50 is available in K-30 after updating:
  • 51200 ISO.
  • Eye-Fi card support.
  • Aperture control in 55-300 PLM lens.
  • Ability to change the picture filename prefix.
Several users of this update have also reported the AF improvement.
The firmware version 1.10 for K-30 can be downloaded here.
Some very important things to understand before installing this version.
Please read the following carefully:
  1. This is firmware 1.10 for K-50 modified in a way that it can be installed in K-30 cameras. It will turn your K-30 into K-50, and the EXIF in your photos will reflect this change.
    If you want your camera to be identified as "K-30" in EXIF information and during PC connection, here is a camera name preserving version.
  2. This is not an official update, and when you install it you'll automatically void your camera warranty (if you still have one ).
  3. This update should still be considered experimental. Flashing it can possibly be harmful to your camera (like any other firmware update, in fact).
  4. During the installation all the camera settings will be reset to factory defaults. If some of them are important for you, please remember their values so you can restore them after the update.
  5. Reverting to the original K-30 firmwares is possible. You'll just need to download and install the official firmware from the update page. But a repeated "upgrading" to K-50 firmware would no longer be safe and most likely will lead to camera hangups - this can be fixed by cleaning the settings via debug menu. I'm ready to give the instructions in case anyone needs them.
  6. Please refer to "Preparation of update" and "Updating Procedure" section on the K-30 update page for the firmware installation instructions.
  7. One of the tester reported random shutter actuations when 55-300 PLM lens was mounted on K-30. We need more testers to find out the reasons of this misbehavior.
If you are still here, I welcome you to the club
Thank you for making this available, I've loaded the version with the name change and so far so good.
I haven't had a chance for extensive testing, but just one point that I immediately discovered, and someone with more knowledge might chime in to say if it's possible, or if I'm dreaming
My K-30 had it's mirror box replaced due to the aperture motor failure, or something like that. I was never satisfied after that, as the difference in exposure between using OVF and LV, was about 1.5 stops, after this download, it seems normal, about 1/3 of a stop...
02-28-2019, 08:01 AM   #171
hnikesch's Avatar
I have been running the firmware for a 1 1/2 years now mostly using the 55-300 PLM lens and I think it is holding off my aperture block failure. I first noticed dark first shots with my 55-300 DAL over a year ago. After switching to the new firmware and a new 55-300 PLM I no longer see dark images with my other Pentax lenses, maybe saving usage on the Aperture block solenoid as most of my images are with the PLM. I do use my 18-135 often without problems hope it continues.
02-28-2019, 03:04 PM   #172
stillshot2's Avatar
QuoteOriginally posted by hnikesch Quote
Does the 55-300 PLM lens use a different aperture control mechanism than the 55-300 DA/DAL ones?
02-28-2019, 03:26 PM   #173
hnikesch's Avatar
Yes it does. It uses electronic contacts and motor in the lens to control aperture
03-18-2019, 08:45 AM - 1 Like   #174
The solenoid with the aperture block is not in action at all when you use the 55-300 PLM lens!
But if you then use it again with another lens the solenoid might be more stuck.
06-23-2019, 05:21 PM   #175
I applied it, and it killed my K-30
06-23-2019, 06:42 PM   #176
retired sw engineer
reh321's Avatar
QuoteOriginally posted by massao Quote
Please use 'Quote' when you reply; what did you apply, and it killed your K-30?
06-23-2019, 07:46 PM   #177
Could you please give some more information?
06-24-2019, 05:10 AM   #178
I'm curious, too. Did your K-30 get bricked by applying the K-50 firmware? I used the hacked firmware that even ID's the K-30 appropriately and I've never had a single glitch. My K-30 happly uses KAF4 lenses (at least the 55-300 PLM) and identifies itself as a K-30.
06-24-2019, 05:21 AM - 1 Like   #179
QuoteOriginally posted by ThorSanchez Quote
He didn't brick it, he stated on dpreview that he was able to get into the menu and reload the K-30 firmware advising that nobody should try this firmware with a used K-30...
I know... Makes absolutely no sense as in my experience of electronics and firmware means it works or you get a dead brick. I remember bricking a PC motherboard once and I had to replace the firmware chip.
06-24-2019, 06:21 AM   #180
I can confirm.
I applied the same firmware more than two years ago and never had a problem.
camera, camera settings, card, cuckoo, dpreview.com, eye-fi, firmware, instructions, k-30, k-30 firmware, k-50, kaf4, lens, memory, menu, pentax k30, pentax k50, post, reset, settings, step, support, thread, time, v1.06
K-30&k-50 firmware bschriver11 Pentax K-30 & K-50 2 02-20-2016 10:40 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
K50 firmware running on a K30? Brownie4u Pentax DSLR Discussion 17 07-18-2013 11:19 AM
For Sale - Sold: K-5, 16-50,50-135,65-250, Sigma 17-50, 50 1.4, 50 1.8, Tamron 90 2.8, Flashes virarfast Sold Items 8 04-04-2013 02:30 PM
For Sale - Sold: SMC Pentax-A 50's: 50/2.8 Macro, 50/1.4, 50/1.7, 50/2 arpaagent Sold Items 14 01-16-2009 08:06 PM
All times are GMT -7. The time now is 11:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
