Originally posted by ekip I just saw a review on Amazon for the Bower amazon.com: Don Phipps' review of Bower LCD Timer and Remote Shutter Release...?tag=pentaxforums-20& and the guy says that the shutter is only half-pressed for the duration of the LONG setting instead of fully pressed when using it with his pentax. It's hard to find out about these things since apparently there is no manual and reviewers skip over the LONG setting.
I just finished reading his review and then got out my Bower to double check the behavior with my K-3. Here are my comments:
- Mine came with a manual, though Bower does not have download from their site. The manual sucks.
- The unit supports both half and full press from the main release button
- Intervalometer functions are pretty standard:
- Delay: Time before start of first interval.
- Long: Shutter press duration (set to zero for instantaneous)
- Interval: The length of the interval between shutter presses
- N: The number of intervals to perform
- Intervalometer shutter is full-press except as explained below
- Behavior is predictable, but with an undocumented feature. For intervals longer than 3 seconds, half-press is done for the final 3 seconds. This feature is very cool in that it will wake up the camera and activate AF and AE if either are enabled.
I can only speculate about the cause of Don Phipps' difficulties. I suspect either user error, something subtle with camera/intervalometer settings, or a defective unit. FWIW, I originally bought my RCLC1R for use with my K10D for timed exposures longer than 30s and for interval work. That camera lacks a built-in intervalometer.
