So with my aperture solenoid behaving itself for the time being after buying an AAdapter to use with my trusty Eneloops (knock on wood), I have been using the camera more happily again.
What sort of "LCD Display Settings" (*) do you guys use? It only recently struck me that mine was very much on the blue side (e.g. giving unnaturally blue sky), and required sliding blue/yellow almost all the way to the right. Man, what a difference. Suddenly my previews are actually looking realistic, and I can appreciate the display's nice viewing angles. I have also adjusted green/magenta 3 steps towards the latter, though this seems less critical.
Is this normal or could the LED backlight be somewhat worn out already? This camera was a refurb with a few thousand clicks on it, so I have no idea how much it would have been used and at what sort of brightness. I wouldn't be surprised to find a tint like that on an LED-backlit screen using white LEDs (= blue LEDs with phosphors), I just didn't expect it to go uncompensated at stock settings with barely any headroom to spare, you know?
My old K-x never required such extreme adjustments - I have it set to M2, combating some presumably age-related greening (on CCFLs, blue foremost and red second tend to fade faster than green for some reason, and if you had a fancy monitor its backlight would have been natively low on green when new, indicating long-life tubes, while a cheapie may always have been a bit greenish). Viewing angles definitely aren't up to par with the K-50's display though, I guess it's some sort of TN - but definitely of the better kind if so, I have seen any amount of TN PC/notebooks screens with plain terrible color shifts in one direction (Samsung panels and the like), and this has none of that.
Liquid Crystal Display Display Settings, but that's what it says in the menu!
