01-04-2019, 09:04 AM   #1
Weird sensor shake during / just after exposure
This started happening with a K-50, is it a common problem and is there a fix?
The sensor shakes strongly in a consistent pattern. I've tried firmware update, changing settings but still no fix.
Thanks
01-04-2019, 09:40 AM   #2
Docrwm's Avatar
Have you checked the dust alert function to see if there's a big area of dust indicated?
01-04-2019, 01:19 PM   #3
ramseybuckeye's Avatar
does it do this using every way of triggering exposure? such as shutter button, 2 second delay, remote, etc.
---------- Post added 01-04-19 at 03:25 PM ----------
You might also try turning dust removal off and see if that does anything.
01-05-2019, 06:39 AM   #4
QuoteOriginally posted by ramseybuckeye Quote
Hi,
Yes, it happens with every way of triggering exposure that I have tried (haven't tried remote). I have also noticed it happens when flipping mirror up for sensor cleaning.
I've tried playing with dust removal settings and no luck.
On closer inspection of the problem one side of the sensor moves up and down in a repetitive pattern.
If anyone has ever heard of this problem please let me know.
Thanks
01-05-2019, 01:26 PM   #5
QuoteOriginally posted by Tigs Quote
Hi,
Thanks
Hate to say it but it sounds like a repair is needed. Hopefully someone that knows more can help you avoid that.
03-30-2019, 03:59 PM   #6
Kevin B123's Avatar
Did you resolve this issue at all?
I have observed my K-50 doing the same thing and I have a theory about it.
I use a lame third party battery to keep the camera alive while I charge the Pentax battery, and I think this lame battery is not providing enough power to run the logic circuits properly resulting in abnormal control set up for the shake reduction.
My K-50 takes perfect pictures and then the sensor shake runs on afterwards.
To solve this I have tried pulling the Pentax battery for 48 hours (ongoing). Then I will try a reset.
fix, k-30, k-50, pentax k30, pentax k50
k 50 shake reduction shake jacques Visitors' Center 6 10-17-2017 11:07 AM
K-30 sensor shake during exposure send2nate Troubleshooting and Beginner Help 12 01-24-2016 06:28 PM
Shake Reduction icon turning off during shaking seattlemark Troubleshooting and Beginner Help 5 12-09-2014 06:05 PM
Weird and scary glitch on monitor during Live View on K5 IIs wafflehaus Pentax K-5 14 03-15-2013 08:19 AM
Shake reduction during self-timer/MLU lhwb Troubleshooting and Beginner Help 8 10-01-2012 05:51 PM
All times are GMT -7. The time now is 08:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
