Originally posted by Not a Number From what I can gather from the German Pentaxians forum the K-70 has a redesigned aperture control block mechanism from the get go. The bears out reports from a couple of Pentax Forums members being told by Ricoh that the K-70 has a different mechanism from the K-50. From photos on the Pentaxians forum the major difference are size and orientation of the solenoid. The mechanisms are not interchangeable between the K-50 and K-70. It appears to use the same solenoid (green) as the K-30/50 and K-S1/S2. Replacing or filing the solenoid on the K-70 seems to solve any dark frame issues should they develop.
This is the problem using google-translator (again).
1. the aperture (diaphragm) controll-block of the K-70 is not redesigned!
2. the diaphragm controll-block of the K-30, K-50, K-500, K-S1, K-S2 and K-70 are interchangeable
3. the mechanism is exactly the same in all of them
4. there is no "major" difference in size and orientation of the solenoid
5. If you claim that "somewhere" "somebody" (Pentax Forum members) being told by Ricoh that there is a different mechanism:
Simply link it. Otherwise it is the "guess of a guess of a guess"... homeopathically refined maybe... but of no use!
6. The solenoid does not "appear" to be the same but it is the same. But the plunger of this solenoid underwent certain modifications since December 2015:
I have documented those steps
HERE
Filing or sanding the solenoid would be utmost silly, nobody ever filed the solenoid itself.
But filing or sanding the plunger of the solenoid is also a very bad idea, because:
1. This destroys the anodised surface and allows corrosion
2. The body of the solenoid is made out of inferior PET. The body wears out more easely. More so if serial-photos are applied for an attempt to get the stuck plunger lose, the PET warms up and the plunger wears it more.
3. The filed plunger moves less precise, which I documented
HERE
So one post with really a "series of wrong claims"
