04-02-2019, 02:36 PM   #16
reh321's Avatar
QuoteOriginally posted by cmichal Quote
Same problem in Av mode, see attached. I checked all the settings for metering being linked to AF point and they're all disabled. When I enabled "Link Exposure and Focus Point" that actually seemed to help a little bit
I wouldn't give up on this camera right now. I loaded both of your images into gimp and generated a histogram for each, as shown below. To my eyes, both photos have potential. I believe either photo could be manipulated in PP to produce what you want. With more experience in using this camera (*) you may be able to get, or 'make', images satisfying to you.
(*) When I first got my Super Program, most of my slides were under-exposed. By experimenting, with different bracketing strategies, I learned how to create slides pleasing to me, and I ended up using that camera for over twelve years, the longest I used any camera as my primary camera, and I still use it on occasion.
04-02-2019, 03:30 PM   #17
reh321's Avatar
As a followup to my most recent comments, if I were you, the first thing I would try would be using the +/- button to adjust Exposure Compensation .... to perhaps -1.5 .... while using the viewfinder. If this comment is too terse, please feel free to ask for a more detailed comment.
04-03-2019, 04:51 AM   #18
QuoteOriginally posted by reh321 Quote
This is what I would do also, rather than just give up on this camera due to the apparent fault. Could be a pain if you switch between LV and viewfinder often but still...
04-03-2019, 06:17 AM   #19
Along these lines when using the viewfinder one could set up a user mode that included the appropriate exposure compensation and other preferred camera settings. That way you wouldn't have to constantly fiddle with -/+ adjustment when going between the liveview and viewfinder.
04-10-2019, 12:47 AM   #20
I would recommend to do a reset!
You go in the menu to the 3rd tab of the setup menu and there you select the reset option.
This is not actually a real factory reset.
If this does not change anything, check your firmware!
Download the latest firmware or even better, download the unofficial magical 1.10 firmware HERE
this is the very best firmware for the K30, because:
1. it allows you to use the PLM lenses
2. the K30 is that bit faster
3. ISO up to 51200
4. because usefull for you, it is almost a factory reset!
Change Noice-Reduction at high ISO to custom settings and set it to:
100 - 400: off
800/1600: 1
3200/6400: 2
12800/25600/51200: 3
You can also learn to go into the Debug-menu, you need to download here:
Dropbox - K30 - Simplify your life
And then report! Very important for those who try to help!
auto, camera, exposure, k-30, k-50, k30, k30 liveview vs, liveview, liveview vs viewfinder, mode, pentax k30, pentax k50, pictures, settings, shots, viewfinder
Underexposed viewfinder, normal LiveView iwtgbtp Pentax K-30 & K-50 5 11-29-2019 10:02 AM
K-5 vs MZ-S vs LX vs PZ-1p vs ist*D vs K10D vs K20D vs K-7 vs....... Steelski Pentax K-5 & K-5 II 2 06-28-2017 04:59 PM
K50 Works with LiveView. Underexposed with Viewfinder AndrewDD Troubleshooting and Beginner Help 7 11-10-2014 05:18 PM
MF vs AF vs Liveview - focus indicator issue?! malenisjaj Pentax K-5 & K-5 II 2 03-02-2014 03:07 PM
M42 lens metering differently in liveview vs viewfinder sameagle Troubleshooting and Beginner Help 15 09-07-2010 07:11 AM
All times are GMT -7. The time now is 02:53 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
