05-09-2019, 01:23 PM   #1
K-30-First the Aperture Blok-Now Green Button Died & Camera Freezes Up!!
My K-30 developed the aperture block failure at about 5500 shutter actuations. I decided to use it for a body dedicated to older manual aperture lenses and have been shooting with it since March. A few days ago, at around 6450 shutter actuations the camera wouldn't respond to pressing the Green Button. I removed and reinstalled the battery fixing the issue.
Tuesday I was taking a few photos and the K-30 locked-up. The camera was one, the displays were working however the shutter wouldn't fire and the camera would not power down. After repeated attempts to turn the camera off, I removed the battery, a different one than when I had the previous issue, and the camera reset when I reinstalled it.
Today, the Green Button decided to work only intermittently! One series of photos it would work, the next-no matter how many presses-nothing. I did the remove and reinstall battery trick several times. Sometimes it would get the green button working. This afternoon the camera locked-up again. had to dump the battery out and reinstall. Then the Green Button quit working completely. I was also having issues with the Catch-In-Focus not firing the shutter too. So now I have a completely useless K-30 with under 6800 shutter actuations.
Has anyone else had similar issues with a K-30/50 with the bad aperture block?
05-09-2019, 01:29 PM - 1 Like   #2
Sounds like this could be a battery voltage issue, which can make camera act unpredictably. Is the battery old or a third-party model?
05-09-2019, 01:36 PM   #3
pschlute's Avatar
I had electrical issues with my K1 recently, the screen would freeze and the camera would not power off. Only removing the battery would solve it , but only temporarily. Had to go back to Pentax for a new electrics board.
05-09-2019, 01:46 PM   #4
Well, both were genuine Pentax batteries. I have Wasabi Power and another generic set. All have worked fine in my K-s2. I'll try different batteries and tLithium AA's in the batter adapter. I can't wait until finances permit so I can buy a new KP or K3ii. I'd like to take this K-30 to the shooting range and dispatch it with my .30-06 rifle.
05-09-2019, 02:28 PM   #5
PJ1
PJ1's Avatar
QuoteOriginally posted by steamloco76 Quote
Post the pics if you do.
But I am sorry to hear about your problems. That is really not very many shutter actuations.
4 Days Ago   #6
Well, it is not a battery issue causing the Green Button to stop working. It intermittently just stops responding with any battery, new, old, fully charged or half discharged. Iím pretty sure the button contacts are ether loose or broken somehow.
I want the darn thing to work because the K-30 seems to give me better images with my older non-digital lenses than my K-s2.
2 Days Ago   #7
I had something similar once with a K10D. Of course no aperture-block-problem but otherwise pretty similar to what you wrote about. It was all about contact problems of pretty much all buttons and the 4-way controller often not doing anything. I took all apart, cleaned everything... and I had to use several tricks to have some parts fixed more tightly. It worked finally but it was a lot of work involved.
But because I remember that you can't undertake DIY yourself, I would recommend to sell your K30 on ebay or similar describing the faults.
Then find out if somebody would sell you a repaired K30 with the white solenoid (or a K50).
1 Day Ago   #8
QuoteOriginally posted by photogem Quote
I'm thinking about going with a used K-3 or K-5ii or K-5iis.
« Focusing problems. | - »
actuations, aperture, aperture blok-now, battery, blok-now green button, button, camera, k-30, k-30-first the aperture, k-50, pentax k30, pentax k50, shutter
Green button fail, may be related to aperture control block failure kernos Troubleshooting and Beginner Help 7 09-01-2017 04:46 PM
D-7 shutter button freezes Julian W Visitors' Center 6 10-17-2013 07:23 AM
Green button and AE-L button voyager13 Troubleshooting and Beginner Help 7 06-28-2012 12:26 PM
Green button or +/- button for meter? kidblue Pentax SLR Lens Discussion 15 07-29-2011 07:10 PM
Sometimes green button, freezes K-5... JohnBee Pentax K-5 3 05-28-2011 09:41 PM
All times are GMT -7. The time now is 11:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
