05-14-2019, 12:54 PM   #1
Focusing problems.
Hello. I have a K-50 kit camera. It comes with 2 lenses:a SMC Pentax-DA L 18-55mm F3.5-5.6 AL WR, and aSMC Pentax-DA L 50-200mm F4-5.6 ED WR.
I get the same results using either lens.
This camera has had very little use but I can't seem to get a good focus using either lens. It doesn't matter if I use it in manual focus or auto focus, the pictures come out with just a little blur in them.
I'm a newbie with DSLR cameras so if you have suggestions, make sure the directions are something I can understand...lolol
I have updated the firmware.
This camera did take great pictures when I first got it a few months ago, it didn't get much use during the winter months but now that I'd like to take some spring time pictures, the focus doesn't seem to want to zero in on my image.
I can manually adjust the focus from completely blurry to actually seeing the image, but it just doesn't get completely focused on whatever image I look at. And when I take the picture and look at it on my PC, the pictures are a bit out of focus.
I'd appreciate any help someone can offer.
Thanks,
Steve in Central Vermont
05-14-2019, 01:05 PM   #2
MossyRocks's Avatar
I would suggest putting the camera into live view on a tripod and see if it can get proper auto focus that way. It may be that the lenses need the auto focus fine adjustment, but if it can't focus in live view then there is a problem .
05-14-2019, 01:06 PM   #3
amateur dirt farmer
pepperberry farm's Avatar
can you post some examples here so we can see what the issue is?
05-14-2019, 01:37 PM   #4
It could well be related to the camera mode/settings. Definitely post some sample shots (straight out of camera) and we'll gladly take a look.
05-14-2019, 04:39 PM   #5
Hello to those that replied.
I failed to mention that I reset the camera back to it's default settings and that didn't help.
Tomorrow, Wednesday, I'll put the camera on a tripod and take some pictures with both lenses and upload them here.
Questions: Should I upload the images directly to this Web site or post a link from something like Imgur with all the images I take?
How many pictures would be enough?
Thanks,
05-14-2019, 06:13 PM - 1 Like   #6
Photo Forum Moderator
photolady95's Avatar
Just a suggestion, but did you accidentally move the diopter out of sequence, fixed for for your eyesight?
05-14-2019, 06:27 PM   #7
QuoteOriginally posted by Blackink Quote
Thanks,
I just noticed that Adam said to post sample shots straight from the camera......
Will Do!
05-14-2019, 06:30 PM   #8
Yeah, jpgs.
05-14-2019, 09:45 PM   #9
How do you store the camera? may be you have some dust inside your camera? Cleaning may help.
05-15-2019, 07:38 AM   #10
OK. First of all, I want to thank all of you that offered suggestions.
The problem was the diopter was out of adjustment. A simple fix for you professionals but it puzzled this DSLR rookie!!! lolol
I actually tried making that adjustment before coming here but I tried doing it with the eyecup piece still on the camera/diopter and it made no difference, that I could see. Once I removed that eyecup and started sliding the diopter to the left or right, it made a world of difference.
Thanks again,
camera, focus, image, k-30, k-50, lens, months, pentax k30, pentax k50, pentax-da, pictures, wr
Problems Focusing on Infinity with K-70 Roger Dier Pentax K-70 7 04-28-2019 10:29 AM
DA*55 1.4 focusing problems Wingincamera Pentax SLR Lens Discussion 6 05-03-2018 01:12 PM
Focusing problems with Tamron 17-50/2.8 Dannyv Pentax SLR Lens Discussion 14 01-25-2018 12:04 AM
Does the DA 50 1.8 have focusing problems? SenorBeef Pentax SLR Lens Discussion 12 12-02-2017 04:18 AM
Pentax 15-30mm focusing problems catastrophe Pentax SLR Lens Discussion 12 11-28-2017 10:00 PM
All times are GMT -7. The time now is 09:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
