11-05-2019, 07:49 AM   #31
hnikesch's Avatar
QuoteOriginally posted by photogem Quote
If it is white-coloured, yes. As far as I can tell it was more in Europe that they already tested the green solenoids in the flash with the K-m
k-x etc. but not USA.
You can install the green solenoid into the flash-circuit of your k-m/2000.
Good point with the green sol
11-08-2019, 01:38 PM   #32
hnikesch's Avatar
Shucks my solenoid started working again on my K30 (K50 firmware) and AV mode does not stop down a non "A" lens. I guess I'll have to use the green button again. It still seems to be an intermittent problem and that for me is a worst case, I never know what to expect from my K30. It was a good excuse for getting my new KP but letting the K30 rest while playing with the kp seems to enable the solenoid to start working again. For a while anyway. Maybe on a rainy or snowy day I will open my KM and K30 and swap solenoids.
07-20-2021, 08:10 PM   #33
After reading thru this interesting thread, I can't help but wonder if what's really happening (broken solonoid or not) is that the camera still captures with same aperture, but the OP is using ExComp. to +x to compensate for the reduced light of the lower aperture, the camera's actually compensating via slower shutter or higher ISO - producing the desired exposure? If this is indeed the case, the DOF will still be that of a wide-open aperture (if solonoid is working and camera is working as specified - by Pentax).
07-21-2021, 12:10 AM   #34
QuoteOriginally posted by kodai84 Quote
With a working solenoid yes but not if the solenoid is stuck. That's the whole point @M42man made.
Here we had another discussion:
Suddenly all pics are very dark? - Page 2 - PentaxForums.com
One member denied it would work although he had the best chance to test it with his ABF-K30 but he chose not to comment anymore even being wrong.
So I had to wait until I had a K-S1 with ABF and did the tests.
aperture, av, block, compensation, exposure, k-30, k-50, lens, mode, pentax k30, pentax k50, stop-down, wide-open
Difference between Av mode and M mode on fixed aperture lens. micl161 Pentax SLR Lens Discussion 12 10-04-2018 08:50 PM
Video Mode - Still changes Aperture in AV mode Snakeisthestuff Pentax K-1 & K-1 II 4 03-08-2018 02:43 AM
Force aperture wide open in M mode without aperture ring? Igor123 Pentax DSLR Discussion 12 11-06-2016 06:32 AM
Aperture ring or no aperture ring hjoseph7 Pentax SLR Lens Discussion 29 12-02-2014 03:06 PM
New camera mode idea: Av-R (Av Relative) Jonathan Mac Photographic Technique 6 04-15-2012 09:45 PM
All times are GMT -7. The time now is 05:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
