10-13-2019, 07:26 AM   #1
AF performance with K-50 and SMC-FA 50 mm/f1.7
Recently I had to test my K-50 with an FA 50/f 1.7 in rather dark conditions (sparely illuminated room) with dancing/fast-moving people. Here I noticed an interesting behavior of the AF: The camera had major problems of finding something to lock on (while using the full reach of the adjustment length of the objective), but as soon as it found something, it could lock onto it even if the light got worse.
Thus, I assume that the initial lock-on is the most important part. Is there something I can do for making it easier for the camera to aquire that lock-on?
10-13-2019, 07:54 AM - 1 Like   #2
It seems to me that contrast is the deciding factor, in low light the lack of contrast is what makes the focus struggle. Finding something with the best contrast should give the camera the best chance to lock on.
10-13-2019, 08:26 AM   #3
pschlute's Avatar
Try a Zebra disco ?
10-13-2019, 09:02 AM   #4
sergysergy's Avatar
In dark conditions it is likely that many cameras will struggle with focusing. When you talk about locking, you mean in continuous AF mode?
10-13-2019, 12:44 PM   #5
ramseybuckeye's Avatar
I assume you have the focus assist light on, if not enable it.
10-13-2019, 02:18 PM   #6
Otis Memorial Pentaxian
QuoteOriginally posted by ramseybuckeye Quote
...and take care to not block it with one's hand.
(...been there, done that...)
10-13-2019, 11:44 PM   #7
QuoteOriginally posted by sergysergy Quote
Not necessarily, also in AF-S. The camera has no problems finding a good focus again after a sufficient focus was aquired, but as soon as I move to another object, it has to do the full aquisition procedure again.
---------- Post added 10-13-19 at 11:45 PM ----------
I tried to avoid that, to not to disturb the people too much.
10-15-2019, 09:36 AM   #8
QuoteOriginally posted by abraxas Quote
You did not indicate but can you confirm you are using the optical viewfinder, rather than live view? The K-50 has a slightly older auto-focus system (SAFOX IX), which is not as good in low light as the later models. You may want to try switching to just the single point center spot focusing mode, so you can point the camera at a specific subject to lock focus.
10-15-2019, 10:18 AM   #9
QuoteOriginally posted by reduno Quote
This ^ ^ ^ ^
10-16-2019, 02:02 AM   #10
Did that, with mixed results. Still, the most surprising result was the fact that it could track objects even when it got darker, but could not reaquire focus on brighter subjects again until it found something useful.
af, af performance, camera, focus, k-30, k-50, k-50 and smc-fa, pentax k30, pentax k50, performance with k-50
For Sale - Sold: Brand New FA 31 mm, FA 77 mm, DA* 60-250 mm, DA* 300 mm ppkkcao Sold Items 14 11-02-2014 08:42 PM
For Sale - Sold: Tak 35 mm F3.5, SMC Tak 55 mm F1.8, and Helios 44K-4 58 mm F2 lenses Vantage-Point Sold Items 6 04-15-2014 03:03 PM
Sigma 50 mm F1.4 EX DG HSM vs SMC Pentax FA 50 mm F1.4 JoepLX3 Pentax SLR Lens Discussion 27 09-03-2010 09:03 AM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
