10-17-2019, 01:16 PM   #1
K50 slow mirror
Hi All. My K50 is taking really dark pictures. Tried a few things and it seems like my mirror may be slow.
1. When I use shutter priority and set a slower shutter speed it takes brighter pictures.
2. Video mode meters the light properly
3. If I take a picture without a lens on the body the picture is still dark. Darker at the top of the picture. If I manually hold the mirror up and snap a pic with the same settings it is pure white.
So... does my assessment seem correct and is there a fix for it?
10-17-2019, 02:17 PM   #2
ramseybuckeye's Avatar
Unfortunately it sound like it could be aperture block failure. Do a search and you’ll find a few threads on it. There is a fix but if you are out of warranty I t will cost you.
10-17-2019, 02:35 PM   #3
Senior Moderator
BigMackCam's Avatar
Moved to more appropriate forum...
Welcome
This does indeed sound like failure of the aperture control mechanism. See the following threads for more information:
Dark exposure problems on K-30 or K-50? Discussion Thread - PentaxForums.com
... and ...
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
Good luck!
10-17-2019, 03:57 PM - 1 Like   #4
Do you have any older lenses with an aperture ring? If the issue is the aperture block, these will still work using stop down metering.
10-20-2019, 02:51 AM   #5
QuoteOriginally posted by Attom Quote
It is almost certainly the solenoid which is stuck.
You NEVER EVER should "manually hold the mirror up", you might do damage beyond repair!
Check it like this in good light:
Use any AF or A lens (those set on A), topwheel on Av:
Chose the aperture for wide open (DA50/1,8 would be 1,8... DA 18-55 would be 3,5)
and take a photo: If the solenoid is stuck it will be almost dark/black
Then with the same lens set it for the largest value such as f22 or higher whatever the lens allows and particular now make sure you have good light because you need it. Now this photo should be fine.
Often photos taken with liveview also turn out alright but not always.
k50, mirror, picture, pictures, shutter
Just got an LX.... and slow shutter speed seem way too slow LFLee Pentax Film SLR Discussion 42 07-14-2016 10:23 AM
Pentax K50 Slow Lazslo837 Visitors' Center 3 02-22-2016 03:07 PM
Slow photography. Really slow... baro-nite Photographic Technique 5 01-03-2012 04:17 PM
effects filters slow down camera,turn off filter and camera is still slow zorak Pentax K-r 7 10-05-2011 06:12 AM
Slow AF? Slow TTL? Check 'em batteries!!! jboyde Pentax DSLR Discussion 11 04-30-2009 06:41 PM
All times are GMT -7. The time now is 04:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
