Originally posted by andyk17 Originally posted by hnikesch I have a feeling this only works on the K50, it didn't work on my K30, I used it in manual using the green button until I got it repaired.
It won't work with the K-30.
I had another K-30 for repair and it was the same. Only K50 and K500 will work that way if the solenoid is down, but metering is not really accurate.
Similar problem like using live-view when the solenoid is stuck:
Lifeview works with the lens stopping down to f4.
But with a stuck solenoid it doesn't open at all, remains closed. And yet the camera does meter and when the shutter opens, the mirrow-up is released
and thus more mA's are available and for a moment the solenoid can actuate. But this doesn't stay that way, after a while the soleoid is more and thus finally stuck.
AA's are just a temporary solution. Sometimes longer, particular if the camera had them all the time in use.
So AA's won't solve the problem really
