03-04-2020, 07:19 AM   #1
purchase used К-50
I broken my old KR - needs replace button on body. I check price repear. In my city - cost repear between 50 -80 USD. And I think about change camera. I check price on K-50. Cost - 150 (body) -200 (body+kit) USD. Account shots about +/- 20000.
Question
1. It makes sense to change KR on K-50
2. How critical is this number of shots for the old K-50
3. What to watch when buying
03-04-2020, 07:46 AM   #2
ChristianRock's Avatar
Sorry to hear about the K-r...
I wouldn't worry about the shutter count, even for the K-50 having 20K actuations isn't really much. Mine has over 40K now, and someone posted here in the forums a year or two ago that their K-50 had reached 500K (that's five hundred thousand) shots
What you do have to worry about is the aperture mechanism. First, test the camera with the kit lens. If the first shot is well exposed, then your solenoid (part of the aperture mechanism) is fine. If it's dark, and the next few pictures get brighter, then the aperture block is failing and should soon fail completely. That is the Achiles' heel of the K-50.
The good news is that with the K-r you have two (I think) white solenoids that can be used to fix the K-50 if you are handy with electronics. So if you get the K-50, keep that K-r body around in case you need to get the solenoid out of it. There is plenty of information (with pictures) here in this forum on how to do this.
If you find a K-5 for around the same price, you might consider that instead, as the K-5 does not have this issue, and also has a nicer more professional style body. Not that the K-50 is bad, but it 's clearly more of a consumer camera like the K-r.
03-05-2020, 12:49 AM   #3
K-5 II (body) can be bought for 230 USD with the number of shots 20-30 000. K-5 IIs 250 USD. That is more than the cost of K-50 by 50 USD. Does it make sense to overpay?
03-05-2020, 01:15 AM   #4
I had two K50's and a K30 that all suffered from the aperture block failure. I've had the K30 repaired and still have it but I sold both of the K50's. That's a rather long winded way of saying that I'd go for a K5 or K5II/s. I also had a K5 and it was a great camera.
03-05-2020, 03:51 AM   #5
I won a K500 (cheaper, no seals version of K50) on ebay and was disappointed to find that it had the aperture block failure. Temporarily cured by fitting lithium AA batteries with a cheap battery holder that I bought from China and shooting a burst or two to unlock it before using it in earnest. After the refund given by the seller it became a cheaper and appreciated buy as I can use it in AF after the burst, live view without needing the burst and of course with lenses that have aperture ring using the green button. So niceish body to have.
But I would recommend looking for a K-5 as recommended by previous contributors and the S suffix version if you would appreciate not having the anti aliasing filter that apparently can provide sharper images than the standard K-5. The K-5 is a great body.
My own K-5 is approaching 100K so may be looking for a replacement shortly and at the moment the K-5iis is as appealing as a used K-3 to me though I have bodies from K100D through K200D, K20D Kr and K500D to use anyway.
03-05-2020, 06:33 AM   #6
Information about the problems of the K-50 drove me into a stupor. I don’t know what to do. I take a photoappart for my daughter. And the dimensions are important. As I understand it, K-5 is bigger and heavier than K-50. With a lens, the weight will be about 1000 grams. Take technically more advanced equipment, but heavy and overall, how much it will be justified. In the direction of K-5, there is one more argument - she plans to go to college as a photographer and it is quite possible the K-50 will not meet her needs. To think and think again. As they say - to buy a car is easier than to sell ...
03-05-2020, 08:52 AM   #7
QuoteOriginally posted by frey71 Quote
Personally, I would get the K-5 II for classes and learning. It's about the same size as the K-50 but 110g heavier (due to magnesium alloy construction). It will have a better interface, be more durable (not just in regards to the aperture block) and have more controls.
If you wanted something smaller than the K-r the only one to suggest would be the K-S1 - quite a bit smaller than other Pentax DSLRs and 50g lighter than the K-r. Some have had the aperture block issue but I don't think it's been as bad as the K-30/K-50.
Positives: better image quality than any of the other cameras you are considering. 20MP sensor with no AA filter, and it's a great sensor in my opinion.
Negatives: the interface is more geared towards amateurs - it will have the scene modes like the K-r, instead of the more pro-like controls of the K-5II. Only one data wheel (but I don't think it hinders me because the +/- button changes the function of the wheel and that's easy enough to get used to). Possible aperture block failure.
Here is a size comparison between these 4 cameras.... Camerasize
Disclaimer: I have not had the K-5 or K-5II, but I have had the K-r and currently have the K-S1 (which was for me a great upgrade to the K-r, and I also have the K-50, and thank God never had any aperture issues - the trick, they say, is to keep shooting your cameras frequently then they won't develop the problem).
03-05-2020, 09:19 AM   #8
The Squirrel Mafia's Avatar
Trust me on this that the K-50 has enough to keep most photographers quite happy. Yes. The AF sucks, but if you're not shooting high speed moving subjects coming at you or going away from you (i.e. birds, kids, dogs, cars, planes, etc.) & do more static shooting, the K-50 has more than enough to please even the most advanced photographer.
The issue here is the possible aperture motor failure in the K-50. I have 2 K-50 bodies that I had to fix on my own. I replaced the "green" solenoids with "white" solenoids in both of them. They've been trouble free since. The black one has been running for almost 3 years since the repair & that's that I did a semi-lousy job on the repair. Hahaha! I did a much better job on the red one.
As far as reliability goes, the K-5/5II/5IIs or K-3/3II would be a far better choice. I'd personally get the K-5IIs or the K-3II. They'll run forever. Well, maybe not forever, but you get the gist.
03-06-2020, 03:44 AM   #9
Dilemma ... I began to think about taking K-3 for myself, and giving my K-70 to my daughter. Moreover, there is an offer to buy a new one for 600 USD ...
03-10-2020, 01:12 AM   #10
Thanks to everyone for the clarification. As a result, I bought a used one K-3 II for 400 USD. Mileage 15000 shots. Must get 15.03. I hope I will not be disappointed.
03-12-2020, 09:57 AM   #11
That is a great deal on the K-3II. I'm sure you'll be quite happy with it.
07-10-2020, 06:30 PM - 1 Like   #12
lgbalfa's Avatar
How would you rate the K-50 by today's standards?
Still a formidable DSLR?
07-10-2020, 09:02 PM   #13
RGlasel's Avatar
QuoteOriginally posted by lgbalfa Quote
To give a short history of Pentax DSLRs relevant to a discussion of the K-50:
In 2010, the K-5 replaced the K-7 as the flagship Pentax DSLR. In 2012, the K-30 was released as a "consumer" level DLSR with the same sensor and auto-focus system as the K-5, but with a reduced feature set. The K-50 is identical to the K-30, except the body is more conventionally shaped, and replaced the K-30 in June 2013. In October 2013, the K-3 was released, which has a higher resolution sensor and an upgraded auto-focus system, along with all the premium features that came with the K-5. When a new K-3 was several hundred dollars more expensive than a new K-50, one could argue that the K-50 was good enough for most people. I got my K-30 in 2012 and have had zero problems with it, but for anyone buying a used camera, the poorer reliability history of the K-30/K-50 cameras compared to a K-3 or a K-5 should make a difference. On to Pentax DSLRs still available new; the K-70 is basically a K-3II Lite and I would call it a formidable DSLR, especially for its price. There is a size and weight difference between "flagship" Pentax DSLRs and the mid-range DSLRs, how important that is depends on the user, but the difference is not dramatic, in my opinion.
07-11-2020, 08:22 PM   #14
Not sure about "formidable", after all that is in the hands of the photographer... If you can take formidable images even an older camera will give great results.
I can say I am amazed sometimes at that sensor in the K50. Some entry and intermediate Pentax cameras had amazing sensors. The K50 is one of them. You can indeed take great images with it.
But newer cameras lime the KP will have an even better sensor, better autofocus, more features including pixel shift, etc... But whether that will translate into better images depends on the photographer...
07-12-2020, 05:10 AM   #15
It is still an excellent camera. Depending on when it was manufactured which you can check here:
Check Camera Shutter Count and Manufacture Date
you might one day encounter aperture-block-failure, i.e. a stuck solenoid.
All K50's built after December 2015 are less likely to fail, but some still do.
If it ever happens to you, then you can apply a simple DIY approach and repair it yourself:
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
I like this 16MP Sony-Sensor which is used as well in the great K5II and K5IIs which I value very much.
The advantage of the K50 over the K5II/s is that it can use the great DA55-300PLM lens, to me the most nasty refusal Pentax ever did towards their customers,
because a firmware-update for being able to use the PLM lens would have been sensible. They did it for the K-S1, so why not for the great K5 series!
Business!
body, change, check, cost, k-30, k-50, kr, pentax k30, pentax k50, price, shots, usd
MC Zenitar-К 1:1.4 50 mm SunnyG. General Photography 18 07-09-2018 12:55 PM
Привет Из Казани. Татарстан. Greetings From Kazan. Tatarstan. Aidar Zali Welcomes and Introductions 5 08-10-2017 03:13 AM
K-3 New under $1050 on ebay nicoprod Pentax K-3 & K-3 II 5 02-06-2014 03:02 AM
Architecture Красивое место у моря drmartin Post Your Photos! 3 12-05-2010 08:37 AM
Night Ночь. Река Кама. drmartin Post Your Photos! 4 08-14-2010 11:47 AM
All times are GMT -7. The time now is 03:08 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
