03-09-2020, 03:03 AM - 1 Like   #1
K10 focussing screen any use?
OK, after successfully swapping the solenoid of a dead K10 into my K30, I just found out that the donor K10 has a microprism diagonal split focussing screen. Can I put that to any use?
From searching the forum I get the impression that the K10 screen is different from the later models. In one of the threads Steve Brot states for instance: 'The instruction photos on focusingscreen.com show a K10 which installs opposite of the one for your K30'
Must say up to now didn't really mis an old type screen. I do have some fast MF lenses however and wouldn't mind experimenting a bit.
I still have an old K200 as well, would that fit?
I bought the dead K10 in the Netherlands and can't contact the seller any more, so haven't got a clue what 'mark' FS it is.
Thanks for your thoughts,
Cheers, Gerard
03-09-2020, 06:16 AM   #2
THoog's Avatar
I don't think the screen is going to fit in your other cameras. The K10D and K20D used the same L_-80 screens, while the K200D used the same screen as the K100D through K-r "low-end" bodies. The K-30 began the standard of the "low-end" and "high-end" APS-C bodies using the same M_-60 screens (so, K-7/5/3/KP,30/50/500/S1/S2/70).
03-09-2020, 10:12 AM - 1 Like   #3
Thanks,
I already feared so, but couldn't find the exact info.
The whole lot will go to the eternal fields then, (unless a K10 owner wants it for just the postage)
Gerard
03-09-2020, 10:20 AM   #4
Fenwoodian's Avatar
FotoGekko, I'll take that K10 focusing screen. I just sent you a message.
Thanks,
Dave in Wisconsin
03-09-2020, 10:50 AM - 1 Like   #5
PM replied to! Considered it 'sold'
Cheers, Gerard
03-09-2020, 12:06 PM   #6
Fenwoodian's Avatar
Gerard, the payment and my mailing address will be sent to you shortly.
Attached is a photo of the little silver latch that holds the screen into possition. It should be fairly easy to disengage it and remove the screen.
Thanks,
Dave
DMC-GX85  Photo
03-13-2020, 08:06 AM   #7
QuoteOriginally posted by FotoGekko Quote
If it ever would be a Katzeye or a Focusing-Screen version, then those are great, particular Katzeye!
The only difference of the K10D/K20D screens to K5/K3/K30/K50/KP etc etc. is the nose.
To be able to use a K10D matte in the K5 / K30 etc. you just clip off this little nose and then it fits into your camera!
I have done that several times and it works great.
Just holding the screen is that bit more fine-tuned work, because you don't want to touch the surface at all!
But I can do it with tweezers and you won't see any damage/mark
03-13-2020, 03:11 PM   #8
Ah, thanks, useful info, but too late! It's on its way to Fenwoodian now, perhaps he can tell what screen it is exactly!
Cheers, Gerard
k-30, k-50, k10, k10 focussing screen, k30, pentax k30, pentax k50, screen
KX - Focussing Screen Mod RR84 Pentax Film SLR Discussion 17 10-22-2016 09:35 PM
For Sale - Sold: Pentax K5 + Meike Battery Grip + Split Focussing Screen benjikan Sold Items 2 09-10-2013 12:59 PM
How can I check if my Tamron 17-50 is front-focussing/back-focussing and needs repair photoleet Pentax SLR Lens Discussion 6 03-31-2013 03:58 PM
Focussing screen! AndersPS Pentax DSLR Discussion 7 04-08-2012 05:56 PM
New old focussing screen for DS whojammyflip Pentax DSLR Discussion 21 07-21-2010 08:58 AM
All times are GMT -7. The time now is 07:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
