Originally posted by Mary Ann 191 Sorry it's taken me until now to respond.
The 55 - 300 lens is the HD Pentax - DA 1:4.5 - 6.3. 55 - 300 mm ED PLM WR RE.
A great lens but not supported with:
Originally posted by Mary Ann 191 The firmware is Version 1.00.
You need firmware 1.10 which you find
HERE
Everything is explained very well
HERE
The term "hacked firmware" or "hacked Pentax" is very misleading, could lead to caution or fear which is absolutly unnecessary because as I have written previously most official Pentax repairshops use it. It is 100% save.
Originally posted by Mary Ann 191 The 18 - 55mm lens is SMC Pentax - DA 1:3.5 - 5.6 18 - 55mm AL WR.
I took your suggestion and cleaned the contacts on the lens and the camera and tried taking pictures again with the 18 - 55mm lens. I was able to take a few with the viewfinder and live view, but the pictures are dark. I also took pictures with the 55 - 300mm lens right after, and the pictures are great, lots of light.
Which explains that with 99% certainty it's the solenoid which is jammed.
Liveview often works BUT, because the aperture is full closed the camera meters wrong, it is set to meter with f4,0!
Only the larger professional Pentax bodies such as K5/3/KP etc. meter more precise and thus better if LV is used.
With firmware 1.10 you can use your K30 and PLM lens even with the bad solenoid, no harm because it is not in action.
Otherwise can only use M-Mode with an A-Lens or Manual lens because you preselect the aperture on the lens itself to your desired value,
press the green button for metering etc, more you find in this forum if needed.
So remember: Pentax DSLR bodies which support the PLM lens are:
- K30 with 1.10 firmware
- K50/500
- K-S1/2
- K70
- KP
- K3/II
- K1/II
Sadly the great K5 series doesn't
Originally posted by iheiramo This doesn't say if you have warranty left. If you do, contact Adorama and get it fixed. Aperture block failure is more time dependent than use related problem.
And yet the fix will only be temporary because they install the China solenoid which in many cases (most!) fails again.
Only after Dec. 2015 manufacture Pentax did something about it, you can read that in other threads I started concering this issue.
I'd ask them to pay 50% back and I'd repair it myself (see the tutorial I wrote).
As Mary Ann 191 likes sewing as well, her fingers could be well tuned for such work!
