Originally posted by stevebrot FWIW, if your K-50 was to have aperture block problems, it would have surfaced in the first 10 to 18 months of ownership.
Some Pentax develope aperture-block during the first 10-18 month of ownership, but only some.
Most develop it later on, many for example when not used for a longer time.
Originally posted by stevebrot The issue is age-related and is not the result of wear or high usage.
Because many develop the problem when not used for a long time, one could somehow say it is age-related, but
the body actually does not age in this case, it is simply magnetism.
But in other situations particular when higher shutter-count it is also a result of wear and high usage!
Because regularely used magnetism doesn't built up that strong but due to the fact that the body of the green China-solenoid is made out of PET
which wears worse compared to PTFE used in the white Japan-solenoid.
@sachmo:
when you check the steps for
Detection of aperture block/diaphragm block failure and you won't be able to reach,
how is it with method #2 and Live-View?
You just switch Live-View on and look into your lens (must be at least an A-lens!)
In M-Mode you preselect aperture and then press the green button.
No solenoid in action!
The aperture-control-mechanism does not control the shutter but both are interlinked, work together.
Because of this any Pentax with a solenoid for aperture-control still works in M-Mode, i.e. the shutter works.
I daubt this is shutterrelated. Your idea about some part sucking suddenly energy sounds possible.
To me it sounds like a mainboard-problem.
I would not send it in for repair, too expensive, for this money you can buy a 2-nd hand K5!
If you shoot manual, the K5 is the better camera! And no solenoid but a stepper motor.
Sell your K50 for parts, any other step than
disassembly for finding out if there are any contact problems (moisture, salt from living near the seaside?) are not worth it, even for this very low shuttercount.
A broken K50 (only if the solenoid is damaged) would cost you $ 80 +/- and then you do not really know it it is the mainboard.
A used K5 is not much more expensive and as you can sell the K50 it brings you that money in.
My suggestion! The K5 is really great for manual lenses. Only drawback: Live-View has no focus-peaking!
But then... a K5 works great with a Katzeye screen!
