No, his K50 is not toasted at all!
(I guess that's what is meant with "it't toast"?)
The steps are quite clear and well described:
- First there was the dark-image syndrom!
- Possibly then, when HoutHand first opened his body, he somehow jammed a cable or similar.
- Then, after he opened it again and reassembled it: All worked fine again.
He was lucky!
That the solenoid actuates again is typical: On a
German website some guy suggests to open the body and then to loosen the plunger with a screwdriver. Not a good idea because as many in the comments suggest it won't last.
Somehow during all those disassemblies of HoutHans Pentax the plunger got that much demagnetised that it now works.
It possibly won't last forever (that is now common knowledge) but with some luck and if he uses his Pentax very regular and with AA's it might with some luck.
