Originally posted by stevebrot The mirror movement and aperture stop down are powered by the same motor.
That is not the case!
Only the aperture stop-down is controlled by the solenoid!
The mirror-up movement is controlled by a motor which happens to sit on the same PCP board as the solenoid.
The shutter is controlled by two pretty powerful solenoids
@HoutHans:
If it would be just the solenoid (aperture-control or also called diaphragm-control-unit) then the mirror would still work.
But if the mirror does not work anymore which is pretty rare this indicates that the mirror-motor is not acting.
This repair is very time-consuming, one has to disassemble the complete camera.
A complex undertaking.
What I would do is to open the camera:
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/385045-manual-solen...id-choice.html
and then check.
Maybe with some luck just a wire broke of.
Did you ever replace the solenoid of this K50?
