07-28-2020, 06:01 AM   #1
K30 Replacement
It's been awhile; looking for guidance from fellow Pentaxians.
I got bored during lockdown/isolation, so I dusted off my k30 only to find it's blocked.
A combo of lazy, convenience, phone and go pro meant I barely used the k30 during its prime (<5k shutter count).
Photos are fine with my primes but I mainly record these days and all my wides are auto.
Any recommendation for a second hand body without running foul of the aperture block?
Probably cant justify dropping cash on a new body and now regretting selling my SMC A28mm after seeing these ebay listings.
07-28-2020, 06:07 AM   #2
amateur dirt farmer
pepperberry farm's Avatar
QuoteOriginally posted by MagusAku Quote
K-5 or K-3 series don't seem to suffer this issue...
my suggestion on the K-30 is to get an OEM M42 adapter for it and build a Takumar collection...
07-28-2020, 06:59 AM   #3
The Squirrel Mafia's Avatar
Get more older lenses with aperture rings. Its the only way to keep using that K-30.
There is a "risky way" of updating the K-30 firmware with a hacked K-50 firmware for the K-30. This will allow you to use the newer KAF4 lenses like the DA 55-300mm PLM that have the aperture motors in the lenses. Those lenses don't use the body's aperture motor.
07-28-2020, 07:15 AM   #4
macman24054's Avatar
Second on the K-5 and K-3. Wonderful camera bodies and a good upgrade from K-30. I've owned them all. Still have the K-5 and K-3.
07-28-2020, 08:55 AM - 1 Like   #5
ChristianRock's Avatar
I think the KP should not have that issue either. It's a current model though, so it will be more expensive even on the used market. But also, being a current model, will give the best image quality in APS-C that Pentax has available today.
07-28-2020, 09:17 AM   #6
Kozlok's Avatar
The newer entry level bodies still have the problem, but to a less extent, apparently (KS-2 and K-70). The K5 and K3 do not since they have a different mechanism.
I'd think a used KS-2 would be worth a gamble, but for similar money, a K5 might be more reliable.
07-28-2020, 09:42 AM   #7
jatrax's Avatar
Maybe repair the k-30? There are instructions here: Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com
07-28-2020, 11:26 AM   #8
E-man's Avatar
If you're on a tight budget, a K20D might be a good solution. Former flagship model with only two fewer megapixels and a lot more bells and whistles than the K30. They're going pretty inexpensively these days.
07-28-2020, 01:30 PM   #9
Another vote for the fine K-5II / IIs. Great camera and inexpensive used.
07-28-2020, 01:43 PM   #10
A Pentax K-5 IIs is a nicely performing and well built camera. I have one and it has done an excellent job.
07-28-2020, 01:49 PM   #11
This and few Eneloops will hold you for sometime.
amazon.com : VONOTO Camera AA battery holder Box Adapter Bracket for Pentax KR K30 K50 K500 39100 D-bh109 DSLR* : Camera & Photo?tag=pentaxforums-20&
I would buy a KP, seems to be good value or a real cheap K-5.
07-28-2020, 08:17 PM   #12
rr1736's Avatar
I think a K-5 or K3 would be a great upgrade but if you could find the money for a KP it would be a great up grade. The KP uses the same battery as the K30 . I have a K30, K5, K3 and a KP and the KP is a favorite. The K3 is a very durable camera I have well over a 100,000 on mine and no problem.
07-29-2020, 06:50 AM   #13
Thanks all. Time for the ol' analysis paralysis.
Think I'll try the battery adapter with enloops and keep an eye out for an old K-5/3.
If I was going to drop the cash for a new body (KP, K-? II etc) I'll probably sell up shop and look for something more video friendly like a Sony.
On the K-30, I took it for a walk today and found other issues with the electronics on top of the ap block. AE a bit off, AE-lock was a hit and miss (compose, ae-l confirmed with symbol, press shutter, it recomposes and locks on something over/under exposed), spinning dials does nothing (works again after you toggle mode).
07-29-2020, 11:55 PM   #14
Does this look decent you think? 2nd hand k-5 with 12mth warranty and free delivery AUD400 (USD285)
Pentax K5 Body | Secondhand | Ted's Cameras
I guess it depends on the condition as well but I'll probably inspect it in store vs a blind online purchase.
07-30-2020, 09:52 AM   #15
Your K-30 with 99% certainty has a stuck solenoid, you find that out for sure:
https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/402053-detection-ap...-k-50-k500.htm
and you repair it this way if you feel up to it:
How to exchange battery-hook on Pentax K-30/K-50/K-70/K-500 and K-S2 - PentaxForums.com
You can download firmware 1.10:
and thus use it for KAF4 lenses as well, I would do this no matter if repaired or not repaired.
This download is 100% save, there is ZERO RISK!
Even official Ricoh repairplaces use it since years.
Otherwise, the K5 is a very nice body, K5II/s even better but those cannot handle KAF4/PLM lenses!
Investing in better lenses such as the DA55-300 PLM will bring you more fun it you dare DIY!
k-30, k-50, k30, pentax k30, pentax k50
Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice photogem Pentax K-30 & K-50 204 03-20-2024 01:14 AM
Looking for a used/broken k30 or k50 for replacement parts AmmonsImages Pentax K-30 & K-50 3 12-27-2018 04:57 PM
My K30 is about to die... looking for compact quality-equivalent replacement manufocus Canon, Nikon, Sony, and Other Camera Brands 35 12-10-2017 01:14 PM
K30 replacement parts jeantarrou Pentax K-30 & K-50 12 07-05-2014 03:24 AM
All times are GMT -7. The time now is 05:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
