Originally posted by Blackink You mention a firmware upgrade. I have the latest 1.10 firmware for the K-50 camera. I should be good if that is all I need is a firmware upgrade, correct?
Yes, your camera is up to date! The lens will do wonders on this body!
You have to know that this lens will not use the aperture block of your K-50, that means two things:
- If your camera, one day, has an aperture block failure, your lens will still completely functional
- If you use only this lens and no others, you will not "train" the aperture block, which may lead to its failure (unless it was already replaced by a white solenoid, in that case, there is no worry to have)
