Quite often the
"Seiko MS414FE FL26E" back-up battery gets drained too much and won't hold the date and personal settings anymore!
This happens particular if you leave your Pentax without it's main battery (no matter if Li-Ion or AA's such as Eneloops) for a longer time! The MS414 is a Lithium and if depleted one cannot "wake it up" again". Similar to CMOS batteries on mainbords.
Those batteries have a leakage current of about 0,2 ľA
These three similar 3V Lithium rechargeable batteries work as well:
- MS518SE FL35E
- MS621FE FL11E (this one I have tried with success)
- MS920T FL27E which has a larger diameter but
is 0,1mm thinner/slimmer than the MS621FE, so no problem at all!
If you search for exactly these battery model numbers you'll find them cheap.
I prefer the original Seiko or other "made in Japan" equivalents.
To get to the mainboard you first follow all the instructions given here in the tutorial for replacing the green China-Solenoid against the venerable DSLR Japan-Solenoid:
1. Manual solenoid replacement Pentax K30 / Discharge flash-condenser / Solenoid choice - PentaxForums.com 2. Then you get the back part off as well, the mainboard can be seen with the backup-battery (green arrow).
>> Unplug the connector of the backpart to the mainboard (red arrow):
A close-up photo of the MS414:
You can see, the space is large enough to actually place the MS920T FL27E there!
All the larger Lithium rechargeable batteries have more capacity which is useful to us because we want to avoid having to unsolder/solder the battery a 2-nd time, those contacts are tiny and really good soldering abilities are needed for this!
I once messed it up and damaged the contacts! This was due because I believed the claim, that this ELNA Supercap:
DCK-3R3E204T614-E
would fit as well and purchased it from USA. It didn't work!
Maybe there are K30/50/500s on the market which use it, so I will not exclude this possibility of course.
And yet: Every K30/50/500 I had open until now had only the MS414 inside. Same for older Pentax bodies.
Thanks to member
@Philber we now know that if we use the MS621 and all others which are thicker,
one has to insulate this metal section on the back-part (blue arrow):
If you forget to insulate this part (blue arrow) the backup-battery will be shortened and drained very quickly because the backside of the battery is PLUS (+)!
Make sure that when you solder the two pins of the battery onto the mainboard that you don't "bridge"
Plus and Minus accidently!
The battery is pre-charged and you don't want to drain it right away!
Again:
This is for those who are really able to solder tiny contacts. Soldering the solenoid is peanuts compared to this.
Datasheet for all those Seiko MS-types attached
Good luck!
Reason: further information added
