05-16-2021, 11:42 AM   #1
Problems through the viewfinder
I have a Pentax K-50 which has been trouble free for some years. I have now found that photograhs I take using the viewfinder are dark as if shot in low light. When I use the Live View option the picture has the correct level of exposure. I have tried to solve this (for example setting the camera back to default settings) but this has had no effect. Are there any suggestions as to how I can solve this (without having to get it professionally repaired)?
05-16-2021, 11:56 AM   #2
i_trax's Avatar
faulty solenoid
I have the same problem with my K-30.
You need to replace solenoid in your camera , look at this , many useful links :
My beloved K-30 finally failed - PentaxForums.com
05-16-2021, 05:22 PM   #3
Aperture control block failure.
Dark exposure problems on K-30 or K-50? Discussion Thread - PentaxForums.com
05-16-2021, 06:31 PM   #4
Unfortunately, what they said^. Fortunately the fix isn't too bad if you get a good solenoid (Japanese white one).
05-17-2021, 04:09 AM   #5
Interesting that live view works. Is this still consistent with the aperture block issue?
05-17-2021, 05:41 AM   #6
It is consistent with the early stages of failure.
Live view holds the mirror up so only the solenoid has to operate during an exposure meaning it has all the power available. With an normal exposure the mirror is being lifted at the same time meaning the solenoid is sharing the power.
05-19-2021, 12:53 PM   #7
Thanks for the information. So it seems to be a problem with both K30 and K50. Is this a problem with later Pentax cameras? Does thsi occur with other makes of camera?
camera, pentax help, photography, troubleshooting, viewfinder
How difficult are K-3 III AF points to see through the viewfinder? Gray Pentax K-3 III 35 19 Hours Ago 02:33 PM
K70 will only autofocus and shoot in monitor mode, not through viewfinder snobrewer Troubleshooting and Beginner Help 8 02-06-2021 03:06 AM
Crack or mark visible through viewfinder Matty Pentax K-70 20 07-25-2019 06:31 AM
Abstract "Through and Through" ginnyfoos Post Your Photos! 2 07-30-2018 08:30 AM
Nature Through-and-through. pavpen Photo Critique 2 05-02-2014 04:22 PM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
