Originally posted by tfa Hi, interesting read, it seems the main problem is in soldering once the cmos battery is located and the heat problems associated with that. Does anyone have any experience with the electrically conductive glue that seems to be available these days?
It would be a different out come if this method was shown to be practical.
When the CMOS is on the backside of the mainboard, there is a lot of soldering required.
I would not recommend to re-solder with concuctive glue.
If you manage to unsolder those wires, resoldering is the least problem.
The bigger problem is with the more modern Pentax DSLR's since the K-S1, K-S2 etc.
Their mainboards are smaller, everthing is very tight.
Soldering there is super tricky. I have done very fine soldering (under the microscope partly) but here it is different.
Too many critical parts very close to the soldering points, very easy to do damage.
