Originally posted by micl161 I have a K30 and it had aperture block issue as well. As you mentioned, I use it on M mode with lenses with aperture ring. I found that the lenses with 'A' setting on the aperture ring sometimes have weird exposure while the M or M42 , Tamron adaptall lenses are more stable. I just forget the 'A' lenses on the K30 for now.
There's an odd quirk about failing K-30/50/500: they stop the aperture down in Av mode. Not only do you not need to use the green button,
but you get more accurate exposures. (I'm talking about K-mount lenses with aperture rings.)
The only negative is that you need to do what a normally functioning camera would do, in terms of evaluating the correct exposure for the set aperture following its wide-open metering. So, you need to use exposure compensation: for example, if you have an f2 lens mounted, and you set it to f4 (i.e. 2 stops down from wide-open), you need to set +2 EV of compensation.
And it works a treat.
The negative is that many vintage lenses are zooms with variable aperture (e.g Pentax F35-70 f3.5-4.5), so you may need to do some manoeuvering to get the right compensation. But for constant-aperture lenses you're fine.
