08-19-2021, 08:01 AM - 7 Likes   #1
K-30 and other cameras using D-Li109 batteries: Sony NP-F external batteries?
Picking up on DrawsACircle - see here
Battery/AC adaptor question - PentaxForums.com
for the tip about the 8k mAh external LiPo battery for those of us with Pentax cameras using D-Li109 lithium batteries.
It is essential to extend the charge for some outdoor photography like astrophotography (I bought K-r for this reason) or camera trapping.
For the latter I bought K-30, really great camera for this kind of activity.
However, the original Pentax 7.4V battery will not last throughout the night until the morning because the power has to be on all the time, nor would even 4 AA Eneloop rechargeable batteries, especially if outside it is cold.
There is the need of enough battery power for the motion sensor to trigger the camera, and itís not good enough the camera is just on.
As there is no official Pentax external battery pack for the K-30, I came up with the following solution:
NP-F battery for Sony (I use DSTE NP-F750 with 5k mAh 7.4V 37Wh) on NP-F adapter plate + 5.5x2.1 female to 4x1.7mm male adapter connector + D-Li109 battery dummy, and it works like charm for days in a row (x5 time of original battery).
This solution could work for astrophotographers too, for those of us owning Pentax K-30, K-50, K-70, K-500, K-r, K-S1, K-S2, K-2, all using D-Li109 batteries.
IPad Air  Photo
IPad Air  Photo
08-19-2021, 07:17 PM   #2
jumbleview's Avatar
Sounds like valuable solution. Should work for KP as well, right?
08-19-2021, 09:46 PM   #3
A useful work around and personally I would use the DC Jack port and seal off with bluetack to maintain WR of the camera. A 12 volt battery with tin can inverter to plug adaptor supply into. Probably as many different ways to do this as photographers who need it.��
08-20-2021, 12:30 AM   #4
QuoteOriginally posted by jumbleview Quote
With the KP you'd need to leave the battery door open … might be a WR sealing issue … should be good with the K-70 which is designed to use an adaptor like this (no DC jack), don't know about the others.
EDIT : The KP DOES NOT work with a Pentax-original 'dummy' battery (for the K-70), so may be problematic with a third-party item as well.
08-20-2021, 03:44 AM   #5
Michail_P's Avatar
An interesting solution.. Thank you for sharing.
08-20-2021, 07:01 AM   #6
Hi, as for K-P see here
Glorich K-AC128 D-AC128 K-AC109 K-AC168 D-DC128 Replacement AC Power Adapter Kit for Pentax K30 K50 K70 K-r K2 K-S1 and K-S2 Digital SLR Cameras,D-Li109 replacement(but not compatible with Pentax KP): Amazon.co.uk: Electronics & Photo
it says although it uses the same d-Li109 batteries as K-30 K-r etc. the K-AC128 power kit will not work with K-P. So the dummy cannot be used. K-P uses K-AC 167 power kit instead, so without a dummy d-Li109 battery. Therefore I do not think the NP-F solution will work for K-P.
Btw, the battery door with K-30 and K-r will close because there is a removable rubber plug to let the cable go through.
08-20-2021, 07:29 AM   #7
QuoteOriginally posted by strixaluco01 Quote
I can now confirm, the KP doesn't work with the dummy battery for the K-70 fitted (Pentax original equipment). The dummy battery will neither latch into place nor will it power the camera if held in place manually. Possibly something to do with the little protrusion around the "T" contact on the original battery which is not present on the dummy.
Sorry for any confusion
08-20-2021, 07:45 AM   #8
jumbleview's Avatar
Thanks everybody for clarification regarding KP. Saved me some money and time.
08-29-2021, 10:09 AM   #9
A better solution for people not having a dedicated LiPo charger with balancer
adapter, batteries, battery, camera, camera trap, cameras using d-li109, d-li109, d-li109 battery, dummy, external power packs, k-30, k-50, np-f, pentax, pentax k30, pentax k50, solution
Pentax D-Li109 battery for the K-30 - has anyone else had this happen? jeallen01 Pentax Camera and Field Accessories 18 09-04-2022 08:01 AM
Which batteries do you hate, and why (AA NiMH vs. D-LI90 vs. D-LI109)? fredralphfred Pentax DSLR Discussion 32 01-30-2022 05:52 AM
Recs wanted, 3rd party D-LI109 batteries & travel charger, memory card Riverlady Pentax KP 17 12-11-2018 06:19 PM
For Sale - Sold: D-LI109 3rd party batteries (2) and wall charger mamethot Sold Items 3 02-24-2014 09:48 AM
Third Party D-LI109 Rechargeable Batteries Drom Pentax K-r 24 06-12-2012 11:33 AM
All times are GMT -7. The time now is 11:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
