Originally posted by BJMCG Hi Guys,
I'm new to the forum, so apologies if I've posted this incorrectly.
My K-50 developed the aperture solenoid problem. I bought a cheap working K100D Super with the intention of using one of its Japanese solenoids to fix the K-50. However, when I opened the K-50 and looked at the solenoid, I noticed that there is a small magnet floating between the two arms of the solenoid...I flipped it, and flipped again, to see if the was a difference in how hard it held the armature in place...I found that flipping it from the original position resulted in a less powerful pull on the armature. My K-50 is now working. This might be just a temporary fix...I'll let you know how it goes. The K100D has proved to such a cracking little camera and I'm glad I didn't have to scrap it, at least for now.
For sure it is only a temporary fix, if you would have unscrewed the the solenoid to take the plunger in and out you'd have the same effect:
The magnetism is gone for a while and thus the holding force is less for a short while.
It is sad because you already did 95% of all work, getting near the flash solenoid of your K100D is anyway pretty easy.
So swapping those two solenoids, the green one from your K30 into the flashcircuit of your K100D and vice versa was more or less right in front of you. So no scrapping of your K100D at all.
Disassembling cameras several times weakens the plastic-threads for fixing the screws! Particular that one deep in the battery compartment. You must then fix it with some extra glue or push something into the hole so this screw can get a grip again:
And you MUST do this, this screw is very important!
That is why the changed this with the K-S2 and K-70, there is no more screw there, the front and top grip in a different way into each other to hold tight.
