Originally posted by TeresaK50 Thanks for you response.
I've tried the first set of steps and both photos come out fine. In the meantime I did a factory reset and found that when I changed the AE metering to spot (which is what I think I'd had it set to prior to the rest) the photo I took was dark, when I changed it back to multi-segment it was fine again. That definitely didn't happen with the previous version of the firmware but I think I can live with that limitation.
Could you please send me the link to the previous firmware version in case I need to revert.
Running K-50 firmware on K-30 - PentaxForums.com
You need to work yourself through it, I have reverted once or twice the firmware "just for fun", it works.
But it is spoken about right there on page 1 (for example #8 by ABel) and how to "trick it".
But I daubt it very much that your problems come from this 1.10 firmware!
You see, many official Pentax repairshops used this firmware when they had a K30 to repair.
Thousands have used it, I myself at least 30x and never without any problem.
I gave others the hint to do it and know of many users with 100% perfect experience.
Never a complaint.
There was once a discussion on the German Pentaxians forum 2 members claimed that they had studied our "1.10 firmware on K30 subforum" but their understanding of the English language was more or less pn a toddler-level. Their translations were a joke but they they tried to ridicule it. But after a while they "turned out to look like stubborn donkeys"....
There have been other attempts there by other "chicken-hearted" members trying to question the savety.
Which again is a joke. I had a real specialist for such things invest the download, it is 100% save, no bugs, nothing.
Changing settings will often delay the regular ABF symptoms but more than 50% of all K30's got hit by ABF, so it is a very likely "option".
