Originally posted by 5pts4slytherin FWIW, I was able to repair my K-50 during a quiet pandemic weekend a couple of years ago. It had been afflicted by the solenoid issue and had sat unused for a few years when I finally learned of the cause and possible solutions. I followed the "sanding" approach, just slightly rounding the corners/edges of the solenoid plunger.
To those in USA who aren't able to apply DIY I have recommended against my own warnings (see
HERE) to send their Pentax to PC35 Photolab in California because they give a lifetime warranty and thus one has a lower risk.
Nevertheless we had as well problems with their sanding approach which you can study
in all detail here in this thread
I find that if one takes on a job which you define as
Originally posted by 5pts4slytherin .....a tricky job with so many tiny bits and I was resigned to the possibility that it might be the end of the camera
and, knowing maybe that if one has to do it again because it can fail and then risking that a few screws might not tighten anymore because the plastic threads are worn too much now
* (which I have encountered many times with Pentax DSLR having been repaired with the sanding job and later failed again) .... the question arises why not doing it 100% proberly, i.e. investing either a bit of time for finding a 2.nd hand donor Pentax or purchasing the solenoid on ebay.com???
There is another problem when recommending the sanding-job:
At least half of those "sanded" Pentax bodies which I had on my desk for repair were purchased in good faith because the seller claimed "aperture failure repaired" and later on the buyers had the problem of ABF and sent their Pentax to me.
So the sanding job is loved to be used by those who want to get rid of their Pentax.
Originally posted by 5pts4slytherin I didn't take steps to discharge the capacitor, but the camera did sit for a few days without the battery
This is too risky because if the camera just sits for a few days without the battery the capacitor keeps enough charge so you can get quite a surprise jolt.
This is a well know phenomen and because if this I gave the very simple recommendations how to discharge the photoflash capacitor if one feels too uneasy doing it with either a lightbulb of a resistor in each tutorial but I wrote a more detailed tutorial
HERE with quite a lengthy discussion which partly was based on sheer theory but gives a deeper insight into the problem.
HERE you can see that pretty tricky section of the K30/50/500: Very easy to touch it while working on it,
very different to the K-S1, K-S2 and K70 were we don't have such a crictical contact area!
I don't think it is a good idea to tell others "I did it without discharging and it worked".
You just were lucky that you didn't touch the spots which would give you that jolt if you did!
*it is particular the long screw inside the battery-box which holds the ON/OFF/Shutterrelease button in position.
It is this thread which often wears out quickly. If the DIYer doesn't realize that then other methods need to be applied so that this important screw will screw in really well and tight then later on the camera will just stop working because important electrical contacts aren't working anymore!
Again, a problem I have encountered particular in "sanded Pentax bodies" which failed again, one has to apply Epoxy into the worn thread, not that easy and... it will wear more if you have to disassemble again.
So to me the sanding job is a stingy job and I can't recommend it. It might work, but it many cases it doesn't and causes further problems.
