Originally posted by JimmyC Photogem, thank you for ALL of your time to help me. I am still pondering what to do, evaluating my finances,etc. JimC
Photogem, I have ordered the white solenoid on ebay. I have seen enough of the videos on taking the k50 apart to feel fairly comfortable. But I have not seen a video where the solenoid is actually replaced. The videos I have seen merely filed down the horseshoe component of the solenoid without removal of the actual green solenoid from the camera. I am in my mid-60's with decent eye sight so I want to use the correct approach to replace the solenoid.
It appears to me to unsolder the wires from the current green solenoid BEFORE i loosen the screw that holds it to the camera. I have read in a couple of posts the wires are "hard" to unsolder because of a wax material. Can you give me any insight into unsoldering the two wires to the solenoid? Would you leave it mounted to the camera while unsoldering?
Assuming I succeed in unsoldering the wires and removing the green solenoid, would I mount the new white solenoid to be camera prior to soldering the camera wires to it?
All advice is appreciated as I believe the removal and replacement of the solenoid will be be most difficult part of the job.
Thank you, JimC
