DA70 patent's crop factor: 1.43x
Originally posted by gazonk Don't forget
the DA on FF thread!
As I understand it, it's usable even wide open, but very soft in the corners.
The bad news is: I'll have to recreate most of its content as the free image hoster with unlimited archival time deleted all of my content ...
The good news is: Meanwhile I learned how to run numeric resolution tests.
MTF50 DA70, f/5.6
center: 3200 LW/PH
short FF edge 1950 LW/PH
extreme FF edge 1100 LW/PH
extreme FF corner 680 LW/PH
The decay in resolution is most likely due to CA as I see double contour lines and a big difference between sagital and tangential resolution (which I averaged). But using B&W film, I cannot really measure the resolution after CA correction ...
Note that the center resolution above is one you cannot see with a 14MP sensor and is about the limit of my measurement setup ...
The attachment shows the deleted image DA70 wide open. Even the outermost extreme corners receive light fully open, so, the ray thru the lens center passes thru. I cannot measure the amount of vignetting in stops as the film used (ADOX) has a very steep response curve and renders vignetting in a dramatic way
So, I added the same shot, but with Gamma=5 applied.
