Originally posted by gazonk I wonder if it still could be quite useful for shots were border sharpness is irrelevant, e.g. portraits?
Originally posted by falconeye I do think so. It carries a "+" in my list
Portraits may not be the best example though as you will probably want to use it wide open. On the other hand, at low ISO the corner vignetting should be correctable. It's probably an excellent FF cityscape and people shots lens.
The lack of sharpness in the corners may be less that it appears if it is due to lateral CA (what I assume) and one applies a true lateral CA correction. A true lateral CA correction is one where the red and blue images are rescaled with respect to the green one. Not one where seam colors are desaturated. Lens correction modules do this.
Technical issues aside, I for one believe that the "problems" of "corner sharpness" and "edge sharpness" and "vignetting" are in large part only really "issues" for "lens tests" and those trying to convince you of the supposed "need" for
new lenses. If you choose a random sample of 100
actual photographs, I'd be shocked if you could find
five that were spoiled
as images (i.e.,
not because someone pixel-peeped and "showed" you that some "imperfection" exists in a much-more-than-likely
completely unimportant portion of the image) because of
any of those overblown "issues."
