05-16-2010, 03:29 PM   #1
RuiC's Avatar
New High Ratio Zoom
Would you be happy with a High-zoom ratio Zoom 30-350mm F5.6 20 elements in 5 groups for APS-C ?
United States Patent Application: 0100033838
05-16-2010, 03:46 PM   #2
Steelski's Avatar
Yes Please
an equivalent 45-525mm at F5.6.......Tasty!!!
05-16-2010, 03:49 PM   #3
rvannatta's Avatar
QuoteOriginally posted by RuiC Quote
It's an intersting design. I hope they build it. If they can produce it with a good quality I would think it would find acceptance. A 1 lens solution has a place.
I"ve often found myself using a fairly high ratio zoom even though I have plenty of primes for logistical reasons.
05-16-2010, 04:07 PM   #4
Thank you for this very interesting Patent.
But why do you say "for APS-C"? The only mention about APS-C is about the equivalent range starting at 45mm.
I guess it could also be the "new" 18-250mm equivalent for a FF camera!
05-16-2010, 05:04 PM   #5
falconeye's Avatar
QuoteOriginally posted by youky63 Quote
Doesn't look like. 350mm, 13x points to 27mm and 60 points to 30mm image diagonal (APSC).
I must say that I find the 18-250mm range much mire appealing than the 28-350mm range. A superzoom really should cover the wide angle part as well. That's more like the 50-500 Bigma for APSC
05-16-2010, 05:45 PM   #6
That's why I think it could be the replacement of the 18-250mm (APS-C, so equivalent 27.5-380mm) but for a FF sensor.
30mm is a very strange "wide" angle for APS-C, and 350mm is not much longer than the very appreciated 50-300mm. So I don't the point for such a lens on crop sensors.
But maybe I just hope to much to find good signs about a FF body...
05-16-2010, 06:04 PM   #7
Blue's Avatar
I didn't see the sensor size in the patent application but I guess I could have missed it.
Could this be a new zoom for the 645d system?
05-16-2010, 06:09 PM   #8
ivoire's Avatar
With a 1.2 million patent office backlog, it may be a while before this lens comes close to being produced
05-16-2010, 06:16 PM   #9
Blue's Avatar
QuoteOriginally posted by ivoire Quote
Not really. It can be produced with Patent Pending or provisional status.
05-16-2010, 06:33 PM   #10
Digitalis's Avatar
if so this lens would probably be a fixed f/8 or it would be a MASSIVE chunk of glass
05-16-2010, 06:35 PM   #11
Blue's Avatar
f5.6 doesn't make much sense for 30mm on aps-c or 24x36.
Edit: What sensor has an AOV of 60 degrees at ~ 30mm focal length?
05-16-2010, 06:51 PM   #12
The f/5.6 mention is related to the 350mm end. But there is no mention about the aperture for wide angle.
And about the AOV of 60 degrees at 30mm, I would say... all of them! Since the angle of view in not dependant of the sensor but the lens (this 30mm on FF is a 45mm equivalent on APS-C. )
05-16-2010, 06:55 PM   #13
Blue's Avatar
The patent states:
[0013](iii) an F-number of 5.6; and
[0014](iv) an angle-of-view of approximately 60.degree. at the short focal length extremity.
actually the sensor size will determine the AOV & FOV. A 30mm lens is a 30mm lens. Why do you think the AOV changes when you take FA 50mm f1.4 lens off of a film camera and put it on a K20d?
05-16-2010, 07:02 PM   #14
The patent states:
Maybe because when you use it on a K20D it becomes a 75mm equivalent... But still the lens can see with a 50mm AOV, just your (my) camera is a bit blind on the borders. ;-P
05-16-2010, 07:06 PM   #15
Blue's Avatar
What do you think I said? It changes because the dimensions of the aps-c sensor is smaller than the dimensions of the 135 film format.
pentax news, pentax rumors, ratio
What's your keeper ratio? jct us101 Pentax DSLR Discussion 48 03-17-2010 01:56 PM
Magcro Magnification Ratio Question GregK8 Pentax SLR Lens Discussion 18 03-16-2010 10:17 PM
LCD Zooming Ratio dazman Photographic Technique 6 12-11-2008 08:46 PM
Pano aspect ratio? schmik Photographic Technique 9 10-11-2008 02:20 AM
Prints and the sensor aspect ratio monstermagic91 Photographic Technique 4 09-19-2008 05:26 PM
All times are GMT -7. The time now is 12:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
