06-23-2010, 02:30 AM   #226
IMO all the hassle about MP number in here is all about pixel density/diffraction, info is below. the answer is yes but only superb glass can handle more MP's on a APS-c size sensor, and thats why 12MP D700 has better IQ than 15MP K-7.
Diffraction Limited Photography: Pixel Size, Aperture and Airy Disks
06-23-2010, 04:35 AM   #227
falconeye's Avatar
QuoteOriginally posted by jpzk Quote
Isn't it a fact that regardless of the number of megapixels, the captor's photosites SIZE do matter?
As I am tired to explain, I really wish you read before you post, esp.
DxOMark - More pixels offset noise!
I do endorse the above article.
06-23-2010, 05:42 AM   #228
mattdm's Avatar
QuoteOriginally posted by Agnostic Quote
Yes and of course when you upgrade a camera it's always a good idea to get the sensor to perform better or at least on the same level as the previous model.... Oh wait, they managed to bring out an upgrade that actually degrades image quality when it comes to dynamic range, noise performance and color depth: Compare cameras
Numbers, numbers, numbers not the whole story. From all I've seen, the K-7 is much less susceptible to patterned noise than the older version of the sensor. Honestly, that's worth a little more noise overall.
06-23-2010, 05:54 AM   #229
QuoteOriginally posted by mattdm Quote
I agree! My K7 produces much more usable high-iso pics than my K20 ever could, as it does not suffer from patterned noise and magenta edges...
Anyway, I now also have a Kx for those it's-so-dark-I-cannot-even-focus shots...
06-23-2010, 06:33 AM   #230
falconeye's Avatar
If testing sites would know their job it would be. After all, pattern noise is ... noise
06-23-2010, 06:47 AM   #231
Yes, but it is an interesting point. How do you measure and value pattern noise contra non pattern noise?
06-23-2010, 07:01 AM   #232
falconeye's Avatar
QuoteOriginally posted by Gimbal Quote
I am 50% thru the development of a new image quality testing method for LumoLabs. It would actually measure pattern noise.
The method basically uses photographs of a fractal test pattern (where I would have to patent or at least copyright the exact pattern) and the spatial power spectrum of original pattern and its photos. The difference is the defect over spatial frequency, after proper treatment of lens and illumination artifacts. Noise would be part of this defect curve.
The great thing is that this measures a camera performance independently from technology. A higher pixel count leads to better performance at higher frequencies but not more noise at any given frequency. Fixed pattern noise shows up as peaks in the defect curve at lower spatial frequencies. A bad dynamic range shows up at lower spatial frequencies as well. And analog film cameras / film can be measured in the exact same way!
06-23-2010, 08:30 AM   #233
Digitalis's Avatar
sounds very interesting Falconeye...I have always thought there should be a way of using fractals as a way of measuring performance of optical imaging systems. though you would need an interesting fractal pattern to test the entire imaging field the Mandelbrot set isn't well suited to such tests. I have used the lichtenberg figure to experimentally test some of my lenses, though field curvature made such testing difficult.
06-23-2010, 09:28 AM   #234
falconeye's Avatar
A, a brother in soul
The Lichtenberg figure may have a two small fractional dimension. It's almost 1 dimensional, like the Mandelbrot set's border.
A started to think in terms of generating functions as well. But now, I think a generalization of the simple idea behind the Cantor set is a better approach. Unlike Mandelbrot an alike, the Cantor set can be easily redefined for 2D.
I am still undecided about the exact interval function (shouldn't be a step function really) and how to treat colors.
It may be less suitable to test lenses because lens properties aren't location-independent. But for sensor tests using a "best" lens in its sweet spot it should work out ok. Unevitable non-uniformity of lighting is another challenge. But it should show up in lowest spatial frequencies only. Where it could be measured for compensation.
06-23-2010, 10:01 AM   #235
Well, maybe a ring flash, or an uniformly back-lighted target, would take care of this?
EDIT: whoops, went right into dumb mode about the ring flash, as the inverse square law still applies... So, this leaves the back-lighted target...
06-23-2010, 05:45 PM   #236
Digitalis's Avatar
QuoteOriginally posted by dlacouture Quote
unless he went through the expense of getting a studio ringflash. It would be possible, they are very powerful and some are capable of providing a very high speed flash. The Elinchrom ringflash is rated at 1/2600th at full power and can accommodate a wide range of lenses. I'll have to get the t= figures but they are bound to be pretty quick knowing Elinchrom.
06-23-2010, 09:22 PM   #237
Class A's Avatar
I've referenced that article before. I'm not sure why it doesn't help more than it should.
06-23-2010, 09:28 PM   #238
Class A's Avatar
Have you considered using something like the Peano curve or the Hilbert curve and use different colours for various iteration depths of the curve?
06-24-2010, 04:11 AM   #239
falconeye's Avatar
Space filling curves won't do it, I guess. You either print finite versions with a peak in frequency space or you get a uniform surface.
My current intuition uses the Cantor set as a starting point. Besides the Cantor dust (which isn't dense enough), the Sierpinski carpet is a well known generalization to 2D:
It has a Haussdorf dimension of 1.8928 and any fractal around 1.7 to 1.9 seems suitable. List of fractals by Hausdorff dimension - Wikipedia, the free encyclopedia lists many of them in a convenient way.
However, I would alter the generation rule. Generalized Cantor sets use a rule to use a uniform plane, tile it into congruent parts, and remove some of them.
I think to alter this rule: I replace a single tile center by N centers of congruent parts. Then, I "attach" a fast decaying function to the centers like a Gaussian with a standard deviation proportional to the current iteration's tile scale. For each tile center, I use a color multiplication factor where black corresponds to the removal of the subtile. Then, I overlay all tile functions with the image of the previous iteration, where the choice of the exact overlay function (e.g., a multiplication) defines much of the final fractal. The choice of Gaussians should make the power spectrum smooth.
That gives me quite some design space and I'll have to write a program to navigate thru the possibilities.
Nevertheless, I'll need hard borders to measure a camera's capability to depict line structures. The above construction only measures a camera's capability to depict point structures. So, I'll have to combine several approaches. So, a standard duochrome fractal probably won't do the job.
06-24-2010, 04:24 AM   #240
yes, numbers everywhere...
I was excited when the K7 was introduced and at first glance decided I would buy one when the price came down..
UNTIL I noticed that there were VERY VERY FEW examples of really good top class portraiture with the K7.
And while this is an observation rather than an exact quantification, the truth of the K7 is that there is a reddish cast to skin color and some sort of a frosted like muddiness because of this cast to my eyes.
Check Flickr, other example sites - there are thousands upon thousands of absolutely great portraits for the K10D, the K20D, even the older ist*'s, but a dearth of great people/portrait shots with the K7. I have just never liked people examples with it despite liking all the performance features that the K7 introduced.
And so I wait now ready to pay first adopter price for a worthy K7 replacement AND ESPECIALLY HOPEFULLY my first choice, a home run Pentax FF (my 31 and 77 Limiteds NEED a great FF!). I need the FF sized viewfinder to do what I want. The K10D's focus faculty and lack of usefulness are making me nuts
I love my Limiteds and at lower ISO the K10D can be stellar, but Pentax I need a home run FF AND a home run K7 replacement
pentax news, pentax rumors
Pentax at PMA 2010 techmulla Pentax News and Rumors 8 04-21-2010 07:02 PM
Pentax Japan finally speaks about the new camera!!!! vitalsax Pentax News and Rumors 8 05-08-2009 03:03 PM
Pentax PMA vievetrick Pentax News and Rumors 11 03-01-2009 10:11 PM
Hiroshi Onada, GM of imaging systems for Pentax Europe speaks... digitalphil Pentax News and Rumors 21 02-02-2008 02:18 PM
No New Pentax DSLR at PMA? RiceHigh Pentax DSLR Discussion 52 02-26-2007 05:05 AM
All times are GMT -7. The time now is 07:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
