06-21-2010, 04:39 PM   #16
thibs's Avatar
But i dont see pentax selling a VC Lens
06-21-2010, 05:01 PM   #17
QuoteOriginally posted by thibs Quote
The Pentax had the same optics as the Tamron 18-250mm, but some different details in build. I suspect that if Pentax went with the 18-270mm optics, they would build it without VC.
Mind you, I consider the 18-250mm to be superior to the 18-270mm, and maybe Pentax would consider the 18-270mmto be too much of a quality compromise.
06-27-2010, 07:24 PM   #18
music_lover
Guest
QuoteOriginally posted by ianchen Quote
Pentax DA★25-350mm F3.5-5.6 SDM?
new patent for the zoom DA★?
a lens of that nature would weigh over a pound and a half
06-27-2010, 07:42 PM   #19
Jodokast96's Avatar
QuoteOriginally posted by kricha6431 Quote
And? An 18-250 weighs 1 lb, a 70-300 weighs just over 1 lb., a 50-135 weighs 1.5 lbs., and a 70-200 weighs 3 lbs. That's not a heavy lens for a 14x zoom.
06-27-2010, 08:31 PM   #20
ogl
ogl's Avatar
There are a lot of lens patents, but the real lenses are much less .
06-28-2010, 01:52 AM   #21
Nope.
It's the patent for an APS-C 25-350 superzoom lens, so certainly not DA*.
It would replace the DA 18-250 which went out of production. However, let me say that 18-250 is a much more useful range for an APS-C lens
Sure for a single lens solution. However, when coupled with a 12-24mm, a 25-350mm covers pretty much 99% of the generally used range for most people. Those two zooms and a few primes for specific or IQ purposes would go a long way of covering most of the bases for a lot of people.
I'm not saying it should be done or is a good idea. Just saying there could be sound reasoning behind such a lens. I think I would personally prefer something that starts a bit wider, just to reduce the amount of lens switching. A 16-90mm F3.5-5.6 with a 70-300mm F3.2-4.5.
07-03-2010, 01:13 PM   #22
rei_vilo's Avatar
Really strange
A 25-350mm lens has a zoom range of 14x, which is far superior to the commonly accepted limit of 4x for quality lens, and thus IMHO incompatible with the DA* branding.
I'd rather prefer a 1,4x or 1,7x SDM-compatible rear converter so I could take extra focal length out of the DA* 50-135 and DA* 60-250 great lenses .
07-04-2010, 02:42 AM   #23
falconeye's Avatar
QuoteOriginally posted by CSpronken Quote
Sure for a single lens solution. However, when coupled with a 12-24mm, ...
The entire idea of a superzoom is to not switch lenses...
QuoteOriginally posted by rei_vilo Quote
One variant of the Tamron 1.4x is an SDM-compatible rear converter and it does work with the DA*60-250. Sometimes slow to lock focus but it does work.
07-04-2010, 03:43 AM   #24
thibs's Avatar
Really strange
Canon 35-350 was (I think it is discontinued) a L lens.
07-04-2010, 06:24 AM   #25
steve1307's Avatar
...yes, meaning it is expensive, quite heavy and painted white.
they also still make a 28-300 L with IS (also a 10x)
It's still a design compromise over the lower zoom ratios (and primes) obviously.
07-09-2010, 11:34 AM   #26
Says who? It may be your idea, for me the idea is too change lenses less often.
f3.5-5.6, pentax, pentax news, pentax rumors, sdm
Tamron Adaptall-1 70-350mm f4.5 worth? rmtschanz Pentax SLR Lens Discussion 7 10-10-2009 10:43 AM
LBA satiated: DA★ 300mm f4 ED [IF] SDM yeedub Pentax SLR Lens Discussion 17 03-14-2009 06:34 PM
DA★ 60-250mm F4 ED [IF] SDM release postponed Noisychip Pentax News and Rumors 33 12-19-2008 01:44 PM
PENTAX-DA★ 50-135mm Samples Collection and Pentax SLR Lens Discussion 18 07-29-2007 05:44 PM
All times are GMT -7. The time now is 04:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
