Originally posted by alessandro63 In Pentax cameras, as in any other DSLR, you can just decouple the focusing from the shutter button, really no need to tape anything nor to switch to manual focusing.
Yes, or one uses the AF button to disable focus when pressing the shutter
What I meant was some camera makes where mounting a lens to a body may change its focus (during protocol initialization) even if all settings are manual. And testers sometimes have to switch lenses within a series and so some tape the lens.
Originally posted by alessandro63 What's impressive is the quantity of variables one must keep in account to try to verify if this issue exists: what do you think is the real incidence of this problem in real life shots?
Alessandro,
your point is valid to a point. We wrote in the Understanding Image Sharpness Paper about. All the factors which add to blur ...
But the problem is relevant in real life nevertheless. I wouldn't say it is the #1 cause for blurred images which is why I can live with that. But make a thought experiment: Assume you have 4 causes each having a 50% chance to blur an image (like defocus, lens softness, motion blur, shutter blur -- simplified model for our thought experiment!). Then the chance for an unblurred image is 6% only. Which isn't that unrealistic by the way. Tack-sharp images are the exception, not the rule (at least in demanding rather than tourist-snapshot situations). If you can then eliminate one reason for blur, the chance for an unblurred image raises to 12%. Twice as many tack-sharp images.
So, even though the single cause is largely dominated by the other causes for blur, it still makes a difference. Reasoning like this can be counterintuitive sometimes.
