LumoLabs: Shutter induced blur with the Pentax K-7 camera
Two of my friends and myself have attempted and succeeded to clarify once and forever the question if the K-7 camera can produce additional blur (compared to, e.g., the K20D). And if so, under what shooting situations. And if so, if there is a workaround. And if so, why.
We found the answers to all these questions.
Please go to
Falk Lumo blog: LumoLabs: Shutter-induced blur with an SLR camera
to learn more.
(This is no plug to create traffic towards my blog. I have no ads on my blog and don't even measure its traffic )
Some more info (skip this if you're going to read the blog article!):
A recent observation made by us and others was that shake reduction efficiency for the Pentax K-7 camera seemed to have a weak spot around about 1/100s and less. Something nobody could really understand and not everybody was able to confirm.
Therefore, we decided to try to answer an old and fundamental question for SLR photography: To which extent does the mechanical focal plane shutter and the mirror slap negatively influence image sharpness? Especially in the digital age with its theoretically rather high image resolution. We, this means two friends (Henning and Rüdiger) and myself (Falk). And of course, we decided to focus our study to the Pentax K-7 SLR camera in order to provde an answer to the observation mentioned above.
The short story is that we managed to find the answers. All our findings are written down in detail in a LumoLabs White paper:
LumoLabs -- Shutter-induced blur for Pentax K-7.
Please refer to this document to actually understand the work we have done. In the following, we will summarize our findings without explaining how we got there. However, note that 4 different camera bodies, data from 4 testers, 8 lenses and two firmware versions have been used. More than thousand test shots and several thousand accurate blur data measurements have been aggregated. High speed video, acoustic recording and acceleration measurements complement the data. So, we assure that the result describe the general behaviour of a Pentax K-7 SLR camera. Pentax has obtained a copy of the paper to be used at their discretion.
We will make no statement about how the results relate to other SLR cameras. Except for a quantitative comparison with one Pentax K20D SLR camera.
Results:
- The mechanical focal plane shutter indirectly can increase the blur in an image. The exact amount of additional blur depends on the direction in the image. It is zero at a vertical contrast edge (aka yaw blur, blur due to yaw movement). And it is up to 11 µm (on average) at a horizontal contrast edge (aka nick blur, blur due to nick movement).
The exact amount of average blur is shown in the opening figure of this article. It has its maximum for shutter speeds of about 1/100s to 1/80s. It is less than 5 µm for 1/25s and slower. Or 1/250s and faster.
Note that any single image can be affected more or less. Add or subtract +/-50% to get an idea of variation from image to image.
Note that one pixel is 5 µm large and the blur effect is only visible if all other sources of blur are very well under control (sharpening, defocus, shake, subject blur, lens abberation, noise etc.). Normally, these other sources mask the effect. Nevertheless, if you want tack sharp images then you need to understand the shutter blur effect. - The effect for the Pentax K-7 is larger than for the Pentax K20D. About 2 - 3x larger.
- Mirror slap or shake reduction have no negative or positive impact on the effect. Shake reduction works as advertized but cannot counteract the perturbation from the focal plane shutter as it is too fast really. Mirror slap is very well dampened in the K-7 camera and has no negative impact on image resolution except on a weak tripod.
There is a delay of about 10 ms between end of mirror slap and begin of shutter operation which suffices to keep the mirror slap perturbation out of the image. - The blur effect is an indirect one:
First, the moving masses of the shutter (curtain etc.) make the body move (with surprising speed and acceleration of its stiff body!).
Second, the body movements cause a classical blur effect lasting as long as the shutter works. The K-7 shutter is faster and stronger than that of the K20D probably increasing the effect by some 60% or so.
Third, the body accelerations cause additional vibrations in the imaging sensor which last a bit longer than the first shutter curtain operates and which magnify the effect by another 60% or so.
Preventing the first from happening (which requires a heavy and sturdy tripod) will kill the effect. There is no "loose" magnetically held imaging sensor and no negative direct impact from shutter curtain or mirror slap causing air flow in the mirror box or whatever. - In practice, you'll only see any effect with wide angle lenses.
At about 1/100s you would normally have blur due to free-hand shake (we can ignore the case of a tripod as only weak tripods would cause any trouble with the shutter). At 50 mm and longer, the shutter blur will be masked and at 30 mm it will have comparable magnitude. It is at 10-20 mm that the effect will be noticeable most.
In these cases, we highly recommend to shoot at 1/25s (or slower) and to enable shake reduction as it is highly efficient at such exposure speeds. The images will be sharper than at 1/100s! - Early efficiency tests of the K-7 shake reduction suggested that it may be ineffective at fast shutter speeds as required for long focal lengths. This was a preliminary conclusion we proved to be wrong.
The Pentax shake reduction is effective even at 1/500s! It just cannot prevent the shutter blur at about 1/100s. We may soon publish an update to our SR guide reflecting this.
Please, read the blog and the White paper before discussing this. Thank You.
