08-20-2010, 10:56 AM   #196
Aristophanes's Avatar
QuoteOriginally posted by TaoMaas Quote
When we say that these lenses can cover FF (and I'm also thinking about Pentax DA lenses here), does that take into account the amount of image circle needed to cover sensor movement for in-camera shake reduction?
The sensor doesn't move far. Like Pentax, Sony uses sensor shift stabilization, so I would assume "yes" to that question. Otherwise it's a design flaw from the outset.
08-20-2010, 11:45 AM   #197
Groucho's Avatar
I thought this thread had died out after going in another tangent, but it's got a flicker of life yet.
QuoteOriginally posted by Aristophanes Quote
No. FF can be as small as the Sony NEX which has a FF image circle and mount by design (the E-Mount is FF).
Clearly Sony anticipates FF in EVIL in the same size package as the current NEX.
All that matters is the price.
Sigh. Again - having a lens mount big enough to fit a FF lens does not mean that the body is big enough to fit the sensor and related electronics.
Note that some NEX bodies actually have the lens mount sticking out past the rest of the body!
It is foolish to expect Sony to release a FF NEX. The NEX lenses are designed for an APS sensor. Sony would have to throw away all their existing NEX lenses and design and release brand-new E-mount lenses which can cover a FF image circle. They'd be in the same boat as most DSLR manufacturers are where they have to support both APS and FF lenses.
And, again, imagine mounting a 70-200mm F2.8 on an NEX body. Ridiculous!
One final note on the lens mount thing. If Wikipedia's lens mount info is accurate, the Four Thirds DSLRs actually have the same size lens mount as Nikon's FF DSLRs! Will you also claim that Olympus was always planning a full-frame 4/3rds camera, because their lens mount (~44mm) was plenty big enough to fit a FF lens? The micro 4/3rds could probably cover a FF sensor also; some 35mm rangefingers have similar size lens mounts.
In other words - please stop beating this dead, meaningless horse.
08-20-2010, 11:51 AM   #198
Banned
If Pentax could come out with a $10,000 645D they sure as hell could come out with a FF DSLR to work with the 24 million FF K mount lenses out there for a fraction of the price IMHO.
08-20-2010, 12:01 PM   #199
OK, we get to disagree again! It's a good day.
I would amend that to say that Sony clearly anticipates FF in cameras using the new E mount - a fine way to spread development costs. I will assume that Sony understands that a new mount is a very long-term commitment - at least to its purchasers.
The form factor may be something else entirely, smaller or larger than the current NEX-5, perhaps of an entirely different shape. That's my current idee fixe. Please see Sony NEX-VG10. May even revert to a new-technology OVF. Whatever that is when it's at home. (I expect EVF, though - easier to create radical designs if you don't have that pesky optical path to deal with more than once.)
Sum: The FF E mount is what we're sure of. Sony's plans may be radical indeed, particularly given the size/weight of FF lenses.
There is more but I really must do some network planning today. I have a meeting with my manager soon to discuss tangible progress. I should have some.
08-20-2010, 12:07 PM   #200
deejjjaaaa's Avatar
QuoteOriginally posted by Groucho Quote
may be at the planning stage they decided not to discard the possibility... are you close friends w/ Olympus desicion makers of that time to say that this was not on their mind ?
08-20-2010, 12:11 PM   #201
Why not? If Moore's Law holds some truth, the image processing capabilities of the non-sensor electronics will shrink relative to their capabilities.
You're trying to put up a physical design barreir that has been broken many times before. The sensor's surface area can stay constant while there can be a dimunition of other electronics.
Sony designed it that way. Ask them.
So you are saying Sony is foolish for designing it to have both an FF E-Mount and have the lens outsize the body, but that this is all really just for APS-C?
I agree, Sony is foolish, for losing money amongst other things, but they are clearly anticipating E-Mount being FF. They went so far as to release the mount solely on an NEX body. Is Alpha gone? We don't know. but anything new has FF built in even though for proportionate sizing and the "EVIL is small" mantra, this seems counterintuitive.
As with past lens mount abandonments, I predict that APS-C mount lenses will eventually be dropped. Both lens and sensors will be FF. This consolidation of design, production, support, marketing, and distribution will save the industry enormous $$$. Right now, sensor costs occupy that space. As FF costs are amortized, that capital will start to flow the other way making it cheaper to include FF through the line.
Did you just see Sony's newest NEX lens announcement?
Sony E 18-200mm f/3.5-6.3 OSS ( NEX ) - Review / Lens Test Report
Tell me again what's ridiculous?
Yes. All manufacturers likely designed the lens mounts to eventually hold larger sensors once sensor prices dropped due to economy of scale opportunities. This would force consumers to re-purchase (reinvest in economic terms) in the technology to continue the revenue cycle.
It's been done before, they'll do it again.
08-20-2010, 02:41 PM   #202
APS-C is not going anywhere. It does not matter how fast technology evolves or how cheap FF sensors become. You will ALWAYS need bigger more expensive glass to make the most of larger sensors. Glass is and always has been what actually separate the customers into different groups. Give any competent professional any modern body and good glass and they will be fine for most types of photography.
The FF advantages are wasted on 80% of the users in the market. The new FF glass that is coming out is pretty expensive compared to the older film era glass, and it needs to be to address CA, LCA, & corner softness. The new Nikon 85mm is long over due and running $1,600 estimated. The new Sigma 70-200 is 2x the price of the HSM II. Any FF advantage is lost with cheap, slow consumer grade glass.
People seem to think Pentax can just dust off the old FA designs and have a successful FF lens line up. No manufacturer has been able to do that with the exception of a couple of lenses.
I would love to see Pentax roll out a FF, but they are a long way away form being in a position to do that. Not because of issues with sensor supply or any technical problems, but because they do not have the money to invest in designing all new glass and brining it to market.
08-20-2010, 03:56 PM   #203
deejjjaaaa's Avatar
QuoteOriginally posted by Winder Quote
Nikon 85/1.8 und Canon 85/1.8 do not think so
you can look @ canon cheap FF lenses from old time tested @ photozone
35/2 @ http://www.photozone.de/canon_eos_ff/428-canon_35_2_5d
50/1.8 @ http://www.photozone.de/canon_eos_ff/415-canon_50_18_ff
85/1.8 @ http://www.photozone.de/canon_eos_ff/419-canon_85_18_5d
100/2.8 @ http://www.photozone.de/canon_eos_ff/489-canon_100_28_5d
no fancy L's, released 10-20 years ago, they do quite OK and sometime very good on FF
08-20-2010, 03:58 PM   #204
TaoMaas's Avatar
I agree with you. I think the lenses tell us what's to come. I can't see Pentax rolling out a top of the line FF camera and saying, "Oh yeah...we've only got a few current lenses that will work with it." I know people say that some of the newer DA lenses will work with FF, but the part that concerns me is that Pentax doesn't say that. And, if the lenses WILL work for FF digital, I can't think of a good reason why Pentax wouldn't label them as DFA lenses. If the lenses meet Pentax's standards for FF, why not label them as such and pick up a few extra sales from the film crowd?
08-20-2010, 04:00 PM   #205
Have you seen the size of K, M, A, F, and FA lenses? That's how big they have to be. The newer glass is more expensive because they'e fractured the market. Those same designs will come down in price (or, likely, the market will inflate to meet them as happened to lenses in the 1970's).
This is not up to Pentax. It's up to the price points the current FF cameras come in at. If Canikon comes within $500 of the Pentax APS-C flagship, Pentax will lose sales and the k-mount will die unless it, too, moves to FF to keep its market share. You are correct about Pentax needing the $$ to rework their lens array. That's their challenge. But they *must* do it or the k-mount is dead.
This is not an if, but when scenario. Within 4 years you will sub $1,500 FF DSLR's and/or mirrorless offerings. Makes one think twice about investing in APS-C DALtd's now, right?
And it doesn't matter if the features are wasted. When has that stopped a market. 90% of 4WD vehicles sold in the US never go off-road!
08-20-2010, 04:11 PM   #206
TaoMaas's Avatar
Aristophanes, I still think your FF cameras are in a race. Can they make it to market before the print market dies and takes with it much of the professional need for FF? When there are no more magazines or newspapers in which to run still photos, who will need FF?
08-20-2010, 04:14 PM   #207
deejjjaaaa's Avatar
do you really think that all those people who buy entry level FF nikons and canons print at all or even if print then print more than 1 out of 10 keepers ?
08-20-2010, 04:33 PM   #208
TaoMaas's Avatar
QuoteOriginally posted by deejjjaaaa Quote
I'm talking about print media....newspapers, magazines. The places where still pictures still rule. Once those are gone, video will replace them and the need for high-quality stills will only be an enthusiast market.
08-20-2010, 05:07 PM   #209
ManuH's Avatar
A couple of points:
1) The Sony E mount will also be used in video cameras. That's also maybe where a FF sensor could be used. Sony didn't target this new mount exclusively for small still cameras. BTW That's also where Nikon and Pentax are at a disadvantage compared to Sony/Samsung/Panasonic: they don't have any experience in the pro video market, they will not build a micromount video camera and their ecosystem will feel less complete as a result.
2) FF lenses are not necessarily bigger to get the same performance as APS-C. An f/4 lens on a FF camera will perform better than a f/2.8 lens on an APS-C camera! Because of the 1.3 stop advantage over APS-C. 1.3 stop better noise performance, 1.3 stop less DOF means that an f/4 lens is like a f/2.4 lens on APS-C... Not to mention it's easier to design a good f/4 lens than a f/2.8 one.
3) I'm not sure APS-C will ever disappear. It may survive for a long time in mirrorless cameras.
08-20-2010, 06:11 PM   #210
Blue's Avatar
Given they don't have a sensor out at present larger than APS-C, it would be awkward for them to say any given lens would cover a larger sensor. That said, all the D FA lenses do cover film. However, Pentax doesn't acknowledge the existence of film shooters or they would still build a film body. The move to eliminate the aperture has opened up a can of
CanofWorms
for use of new DA lenses and the 100mm WR on a lot of vintage film bodies including the mighty LX, MX and K2. What I am getting at here is don't expect Pentax to officially address this until if and when they do actually unveil a ff body.
body, crop, division, ff, lenses, pentax, pentax news, pentax rumors, sensor, sensors, sony, users
Wild rumor: Canon and Sony fighting over Pentax? rawr Pentax News and Rumors 56 09-05-2010 05:10 PM
Pentax is due for a new body soon... jct us101 Pentax News and Rumors 90 07-31-2010 02:28 PM
Will Sony supply the Sensor for future bodies? Reportage Pentax News and Rumors 10 06-22-2010 06:47 PM
Potential Pentax user Terry Cliss Welcomes and Introductions 3 02-14-2008 01:20 AM
Potential new Pentax user AlexL Pentax DSLR Discussion 30 08-26-2007 04:33 PM
All times are GMT -7. The time now is 01:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
