Originally posted by Winder Thanks for the link.
I wonder whether the "Column-Parallel A/D Conversion Technique" is all good news. It seems to be there to increase readout speed but I wonder if it could affect noise in a similar way the
unequal alternating green photosites in the Canon 7D do.
Sony make sure that different transistor offsets are cancelled out by using the difference between "reset pixel level" and "exposed pixel level" but if the transistors have slightly different gains this still has to be compensated for.
One of the advantages of CCD is that a single A/D converter is responsible for all of the pixels, so there is no need for calibration, balancing, matching, etc. Can the Sony "Column-Parallel A/D Conversion Technique" achieve the same consistency?
Also, I'm not sure of whether I'm a fan of on-sensor noise reduction. It may be exactly the right place to combat some noise at the correct level; hopefully it isn't used to produce RAW data where some choice about how to remove noise has been taken away from the user.
Does anyone have insights into the new technology?
