I am happy you are fine without them.
All I did was say FOR ME I want them...your use and my use are different and to be blunt you might be able to GUESS the approximate location of your desired focus point but it is just that a guess. You can have a more difficult time hitting the same point on a subject when such accuracy is needed. It is simply not possible to position the selected focus point with pinpoint accuracy if ya can't see the darn things. And trust me even after over a year w/o them on the focus screen I still feel naked when shooting. One has to adapt to using a focus area and a best guess about the location of the focus point in that area and hope you get close. So I often end up with several more shots to be sure I get the one shot I need or I have to use such a small aperture that I lose all DOF control because it gets too large.
On the positive side it makes me far more aware of using DOF to cover any errors in setting my focus on the same spot even time.
And that, in a nut shell, was my simple and I know quite trivial point for experts around here. For the way I use a camera having the focus points visible all the time is a huge boon to more consistent shots. It even helps when positioning whatever I am shooting to approximately the same spot on my shooting table after having to move the item. Just move it until the focus point is in about the same spot and my shots look more balanced when taking multiples...it's just a useful tool to have as an option...for me...obviously you are better at guessing where the focus points are than me which makes me so jealous...hehehehe...
That is all I am saying...hell make let HoyaTax make an optional focus screen with the points present if people don't like having them there...I don't mind it's worth an extra $60 to me. It's just one of the compromises I learned I had to make after switching...and it may have been a deal breaker but by the time I realized it was too late all my Canon gear was sold and long gone. So I work around the issue best as I can.
