First - I hope that 7D photo is not supposed to represent the best its sensor is capable of. If I see 100% shots like that coming from any of my bodies, including K20D and K-7, I am disappointed. Even my very old lenses can usually produce sharper results than that when viewed at 100%.
Originally posted by SergioFromSF AF-C
Now some may say that it's user error, but consider this. I have tried dozens of times to shoot my kids riding on bicycles either towards me or across from me with AF-C - almost never AF was able to follow them with good focus and pics are a bit OOF. I seem to get better results with F8.0, locked AF at guessed distance. But then what is the point of AF-C?
I'm not making excuses for the camera as I have had mixed luck with AFC (actually, I rarely even try it)... but was the camera set up use all focus points? Having not spent much time playing with it, I assume that if you're set to center point only or user-selected point, that it will only focus on a moving object in that point. I generally use user-select now (after using only center-point in everything up to the K-7) and I think that most of the time when I have a hard time focusing, it's because there's not much contrast in the specific area I've chosen. I probably should play with using Auto more - and weigh the risks of it focusing somewhere I don't want vs not catching focus at all.
Quote: DR
Under normal conditions DR is not a problem. It has been a problem for me under intense sun in the mountains (thin air, more sunlight?). There the shadows are too dark. I can resolve this by upping the EV, than everything is brighter and background is more washed out or using a filter. But again, sensor does not handle this on it's own.
There is certainly more DR there, you just need to use raw. It's not unusual for me to use "fill light"
and "recovery" in Lightroom. Of course, turning down the contrast should give you extra DR, too. The higher the contrast, the lower the DR, until everything turns purely white and black - the ultimate contrast.
I wonder how much of the DR discussion is users expecting lower DR based on lab numbers, rather than real-world results. That being said, I would love to see the DR of the old Fuji DSLRs available in a modern body.
Quote: High ISO
Tried shooting at ISO 800 at churches and F2.4-F2.8, because of low light. Pics are OK, a bit noisy, but Nikon D300 person next to me got MUCH BETTER pictures than me. Her technique was better?
There are so many variables... quality of lens, lens speed, and the big one - the in-camera processing. The D300 may have been putting out jpgs with lots of noise reduction, DR adjust, etc. Look nice on the LCD (which should be basically the same on D300 vs K-7) - not so nice on the PC. This is assuming that you just saw their photos on their LCD and not any other way. Certainly if both cameras were shooting ISO 800, you should see pretty comparable results.
Quote: Megapixels
Frankly, for me a 12MP sensor is big enough, if it delivers good High ISO performance.
Agreed - that's why I find the D700 much more interesting than the A850/900 or Canon's FF bodes. Unfortunately, the D700 has very limited adaptability to other lenses... if a camera existed with the FF D700 (or better still, the improved D3s sensor), with in-camera stabilization, and the Canon's ability to mount many other lenses on it via fairly simple adapters (or even just K-mount and M42s without needing glass for infinity focusing), it would be very, very compelling. Unfortunately, such a dream camera doesn't exist. If the K-5 truly does offer similar high ISO performance, than it will be the closest thing available.
