08-31-2010, 06:49 AM   #301
falconeye's Avatar
QuoteOriginally posted by pcarfan Quote
Can DNG's be aligned and stacked in-camera efficiently with current technology? also, any software out there that would align and stack DNG files and output as DNG.
PhotoAcute stacks RAWs.
It reads the raws, either native as DNGs, or after using the DNG converter when found in its PATH. It outputs linear DNG which is a DNG file three times as large as a mosaic DNG (very similiar to what DxO does except that ironically, DxO doesn't read DNG). But other than size, the stacked result looks and feels like a raw file. I.e., I don't have to fiddle with color rendition prior to stacking. PhotoAcute takes this literally and displays awful colors in its preview process with no negative impact on the result though. PhotoAcute and FocusMagic are two tools everybody should have tried.
As for the ability to do all this in camera, please read the corresponding LumoLabs article. It says something about alignment in Photomatix too.
08-31-2010, 08:27 AM   #302
pcarfan's Avatar
Falk, a very useful article. (so, it seems like given this and the Sony implementation that the new Pentax will align....wonder whether it could be done as a firmware upgrade for the K-7)
photoaccute sounds interesting. Seems like thay don't have a stand-alone program and also not too clear whether it would work with CS2.
Thank you.
P.S: photoacute only has two lenses optimized for K-7 for resolution/lens correction, but I guess it would be fine for merging RAW without lens/camera optimization.
08-31-2010, 08:52 AM   #303
m8o
m8o's Avatar
=photoaccute sounds interesting. Seems like thay don't have a stand-alone program and also not too clear whether it would work with CS2.
Did you accidentally type the opposite of what you meant? Seems they only have a stand-alone program based on the download page, not a PS plug-in. [?]
08-31-2010, 09:01 AM   #304
pcarfan's Avatar
QuoteOriginally posted by m8o Quote
I guess I just assumed it was a photoshop plug-in as Falk had ranked "Photoshop CS3; PhotoAcute ("normal alignment")" first for alignemnt quality, and didn't see stand-alone mentioned in the Photoacute site.
It's cool it has the stand alone (if it does RAW and output in RAW, I guess it has to be stand alone, hah!???? or LR plug-in???)
I am not yet entirely convinced to spend money on it though. I like NR with multiple images with the same exposure (makes sense why Falk mentioned fps) and exposure blending (but, I already have photmatix) and I wouldn't use either feature much.
Wonder whether multi-exposure mode of Pentax camera's be tweaked to doi something similar for NR (more than what it already does, and more in line with photacute with alignment).
08-31-2010, 09:05 AM   #305
falconeye's Avatar
As said, PhotoAcute is standalone.
The camera/lens profiles are only of relevance for resolution doubling and CA/distortion correction everybody is now doing in LR3 (or in-camera) anyway.
Resolution doubling is a cool feature though. I use it with a Nikon D40 Sigma 30/1.4 f/4.5-10 profile as it is giving me good results. Most profiles make PhotoAcute attempt some deconvolution/sharpening but the results aren't up to DxO or FocusMagic. So, I use the above profile (obviously, the Sigma is outresolving the D40 so massively that there is nothing left to deconvolve ). I then do the sharpening with FocusMagic.
YMMV, but I think that profiles in PhotoAcute are no big deal. Except that if you profile another lens you get your copy for free
08-31-2010, 09:17 AM   #306
Eruditass's Avatar
This resolution doubling sounds pretty interesting, I'd like to know how it works. I can see it reducing noise, but doubling the resolution?
08-31-2010, 09:40 AM   #307
thibs's Avatar
Probably the same way Silverfast does wih supported scanners, multipass.
08-31-2010, 10:18 AM   #308
Pentax K5 Camera
Pentax K-r Camera
08-31-2010, 10:38 AM   #309
QuoteOriginally posted by deadwolfbones Quote
Now these are really mystical cameras if one can take pictures with those specs...maybe some rumors are truth in the end
08-31-2010, 11:36 AM   #310
vsl3-e's Avatar
QuoteOriginally posted by StepOne Quote
it has a hotshoe flash, lcd display, optical viewfinder, autofocus motor and self timer, what else do you need?
08-31-2010, 12:00 PM   #311
Agnostic's Avatar
QuoteOriginally posted by vsl3-e Quote
And all that at a weight of 0 gram! Mirrorless cameras, eat your hearts out!
The drawback is of course that it has a resolution of 0.00 Mpixel though at that resolution it must be capable of producing noiseless photos at 1.000.000 ISO
08-31-2010, 02:53 PM   #312
falconeye's Avatar
QuoteOriginally posted by Eruditass Quote
We're getting off topic here, so just one sentence:
It aligns the images with subpixel accuracy and constructs one image with twice the dimensions from them, making use of the fact that images aren't shifted by integer increments of a pixel.
08-31-2010, 03:30 PM   #313
esman7's Avatar
QuoteOriginally posted by weikle Quote
Improved AF performance is more significant,i don't care about the high iso capability since i would use the tripod when i need perfect 100% zoom image quality.
Agreed. Improved AF is key with the new model.
08-31-2010, 04:49 PM   #314
Banned
K-5: 16MP, ISO25600 and 7 FPS worth the upgrade?
For $1,600 no unless it is FF. I want my 28-300, 20mm , 15mm etc FF lenses to be used in FF again.
08-31-2010, 06:32 PM   #315
QuoteOriginally posted by jogiba Quote
Does anyone make a Full Frame camera body that costs $1600? I thought Sony had the cheapest one at around $2000.
color, iso25600, k-5, kr, pentax, pentax news, pentax rumors, release, sec, september, yen
Upgrade to K20D - worth it? ihasa Pentax DSLR Discussion 5 02-25-2010 06:32 PM
worth the upgrade? cinaibur Troubleshooting and Beginner Help 5 10-08-2009 08:54 AM
Upgrade to Tamron 17-50mm from kit 18-55mm: worth the investment? virgilr Pentax SLR Lens Discussion 2 09-04-2009 07:33 AM
K100d super vs K20d?--Worth Upgrade? T_MB Pentax DSLR Discussion 31 09-02-2009 02:12 PM
k10D Is an upgrade worth it? emptydam Pentax DSLR Discussion 10 11-11-2007 04:18 PM
All times are GMT -7. The time now is 11:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
