08-26-2010, 05:59 AM   #16
agsy's Avatar
I also vote for articulating LCD. You really miss it when you get used to it and then you switch to a camera without articulating screen.
08-26-2010, 06:01 AM   #17
Caat's Avatar
QuoteOriginally posted by pxpaulx Quote
Yeah why be against it? If anything the people who wish there wasn't one would probably appreciate being able to turn the LCD around, set the camera to M mode permanently and pretend it is 1970!
Its probably because it's a potential point of weakness and wear, and generally speaking it reduces the potential size of the screen (partly because the screen bezel and hinge mechanims both take up space).
Additionally with the generally poor CD AF in DSLRs shooting in live-view in normal everday situations is less preferable than using the viewfinder and so vari-angle screens are only of use in some situations.
Of course when they are useful they are useful, they wouldn't exist otherwise. Personally I'd use it for macro shooting and that's it.
08-26-2010, 06:08 AM   #18
QuoteOriginally posted by ManuH Quote
I don't understand people against articulating screens. It's just like video, if you don't like it you don't have to use it. In many situations I wished I had one, I tried mirrors and angled viewfinders but they are not as useful IMHO. And the Oly E-3 proved that WR and durability are possible.
1) It increases camera's size
2) It weakens camera's durability
3) It weakens camera's weather resistance.
Thanks, but no. I need durable and reliable gear to take photos, not gadget for everything.
08-26-2010, 06:11 AM   #19
QuoteOriginally posted by Zebooka Quote
don't worry, there won't be Articulating LCD's in new Pentax cameras
08-26-2010, 06:12 AM   #20
QuoteOriginally posted by Caat Quote
Sums up pretty well why I don't wish for one either.
08-26-2010, 06:15 AM   #21
ManuH's Avatar
OK here is one shot I did with a mini tripod, K-7 and the DA 15mm. It would have been so much easier with an articulated screen. I couldn't use the VF as the camera was too low and I was not prepared to lay down on my chest, I'm getting too old for that If Canon had small primes I would even consider a 60D for that feature alone.
08-26-2010, 06:21 AM   #22
ManuH's Avatar
1) so little, heck it's available on much more compact cameras than a DSLR.
2) your assumption. Not necessarily true because you can use it to protect the LCD when not using the camera.
3) your assumption. WR is not waterproofing.
08-26-2010, 06:29 AM   #23
Rupert's Avatar
Don't need it.....don't want it. Just one more thing to break for a use that would be seldom at best. The LCD is worthless in bright sunlight anyhow, which would just leave you with a worthless extension on your camera for any outdoor daylight shooting.
Casio makes an LCD that is fully usable in the brightest of sun, I have used one, and I don't know why we can't get that instead?
Regards
08-26-2010, 06:29 AM   #24
I think those are all pretty weak. If you take a look at the new releases and current existing high end cameras with articulating LCDs, they do not add any significant bulk either at the hinge area nor do they stick out an appreciable amount. Scared it'll break? Don't use it. And finally if you're scared of weakened weather resistance on something you'll never use, how do you ever bring yourself to click the shutter or turn a dial?
08-26-2010, 06:32 AM   #25
QuoteOriginally posted by Rupert Quote
Regards
Why not articulate an LCD that is usable in bright sunlight then? You talk as if rather than using current LCDs in bright sun, it would be preferable just to not have one at all. In that case the articulating design should be great - turn it around, glue it down and forget LCDs were ever invented.
08-26-2010, 06:37 AM   #26
As a general statement, taking a look at the latest announcements it is clear, like video in the past year, articulating screens will be the next must-have. If you want the brand you use to survive, you are going to have to live with these, and future 'compromises.' So, either stock up on a half dozen K7s now, or live with new developments and 'improvements' in future models. I don't think anyone's cameras have ceased taking photos due to added video capability, and I am sure forthcoming models will continue to function despite having articulated LCDs.
08-26-2010, 06:38 AM   #27
It is more complicated to weather seal a LCD screen on a moving arm than one that is integrated with camera body. Weather sealing a separate LCD would also take up more space. There are no models on the market today that combines articulated LCD screens with weather sealing, and there are of course sound reasons for that.
Since Pentax K-5 will be weather sealed, I don't believe in a moving back LCD for it.
Reducing the size of the LCD screen to have room for both the moving mechanism and the weather sealing, is not really an option here - I feel. Not only the LCD screen needs to be protected but also the arm that contains the electronics for the communication between body and LCD screen.
08-26-2010, 06:42 AM   #28
nickthetasmaniac's Avatar
Speaking solely in terms of the E-3, it actually does the opposite for #2 and #3, because there doesn't need to be a hole in the body for a fixed LCD screen, meaning that you can have a completely solid rear plate; making it both very rigid and very well sealed. For what it's worth, I've stood on my E-3 accidentally (all 100kg of me) with no ill-effects...
QuoteOriginally posted by RMabo Quote
Ummm well actually...
E-3, including (rather good) weathersealing and articulated screen. I might get a housing one day...
08-26-2010, 06:46 AM   #29
I wouldn't have a problem if there were not LCD on the high end model (with all of the above said). Pentax's entry level cameras have always punched up a level from their market segment anyway, so putting it in the entry level model would make sense.
My handheld GPS has completely exposed electronic contacts for the USB connection, but it is sealed to a higher standard than the weather sealed pentax cameras (the contacts are similar to those on the battery grip terminal). I think it can be done, but on a higher end model it can also be left out and there wouldn't be too many complaints.
08-26-2010, 07:42 AM   #30
Aristophanes's Avatar
1) Some of the smallest DSLR or DSLR-like cams have them. So, no, this is not always the case. Your making a generalization that is simply not true.
2) Not sure about that. If you are worried, don't articulate. That is a viable option. I had a Canon Asomething (85?) years ago where the screen went funny after 1 month. It was in and out of the warranty repair in 20 minutes because all they had to do was replace the LCD. Much easier to service than a permanently mounted screen, that's for sure.
Also, for ergonomically difficult and low-angle, high-angle shots, one could make a very valid argument that an articulating screen actually makes the shot easier, and therefore it is less likely the camera body will be placed in a riskier position.
3) It's one less long seal around the LCD bezel vs. a small perforation for the wire feed. The LCD bezel could actually be more WR apart from the body of the camera. That may be an advantage.
The knock against articulating screens is fragility; the screen has the option to extend, and therefore leverage with force sufficient to break is more likely. There is yet another moving part in the hinge.
And cost. They add a modest amount to the material and assembly, so that gets passed on tot he customer.
I think it is simply a matter of time before all advanced cameras have an articulating rear LCD. Super thin bezels with OLED screens entrenched across the industry will make it a cost-effective, no-brainer option.
hope, k-5, lcd, pentax news, pentax rumors
K20d + lcd tv soccerjoe5 Pentax DSLR Discussion 23 03-24-2009 10:38 PM
On-camera LCD vs Computer LCD Andi Lo Pentax DSLR Discussion 6 02-07-2009 01:59 AM
LCD frames Gooshin General Talk 4 11-23-2008 09:33 AM
K10 LCD vs K20 LCD wildboar Pentax DSLR Discussion 2 10-07-2008 01:56 PM
Save your LCD ebarbaric Photographic Technique 15 01-03-2008 08:10 AM
All times are GMT -7. The time now is 02:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
