Originally posted by thigmo \
- Self timer lamp in grip position
- Power switch ring around shutter button
- Green button location (although recessed instead of raised)
- Flat prism/flash profile
- Knurled mode dial (although with 4 instead of 3 knurl levels as on K10/K20)
- PC sync port location and cover
- Grip texture looks similar
- Maybe a raw button (when image is lightened)
I think that is the new Olympus flagship (e-5?). Don't mean to burst your bubble! We all know new models are coming, but I don't think this is it - as for this photo, compare to the high end Oly's out there (against your list above):
1. They have the self-timer in the same spot on the e-30
2. I don't know if that is a power switch around the shutter, kind of speculative!
3. Lots of buttons on high end cameras.
4. Oly's most recent 4/3 cameras have pretty flat prisms as well.
5. Oly e-30 has a 4 row knurl.
6. PC sync is in the same spot on the E-3
Last two are speculative as well.
Personally, it looks too rounded, Pentax has definitely been cutting the edges off of their DSLRs - both the K-7 and K-x have decidedly squared looks to them. The prism is about the only visual knod I would give here, it is pretty cut. The top edges are quite rounded in comparison, and just don't fit with Pentax's general design esthetic.
Edit: I definitely don't see that fitting with Nikon either - none of their dSLRs have had the timer lamp on the grip like that, and their mode dials clearly have never come close to looking like the one in the photo. overall trim of the photo has a nikon look, but several of the details don't fit. They also use the small hook ring loops for the strap lugs (like on the K-7), not the more standard flat loop hole shown in the photo above!
