Now that the K-r specs are releases, these are my first impressions. I don't know where to put them in this overflow of posts and threads but maybe, we simply stick with the first thread opened after the release...
So, here we go (I only comment on the K-r body):
The K-r is a K-x with the following changes:
Hardware changes:- Seemingly another sensor with faster read-out but same pixel pitch.
It remains to be seen if it has the same excellent noise / DR characteristics. Still a Sony Exmor I guess. - SAFOX IX with same AF point layout and focus assist lamp.
Spec says EV-1 to 18 which is a first to be specified and a great spec!
SAFOX IX has the same name as the 645D AF module.
Testing it may be interesting indeed - Illuminated AF points.
- 921k dot rear screen.
- 6fps.
- Combined LiOn / NiMH battery compartment.
- Capable of sending images via infrared beam.
- 5mm higher, 2mm wider, 26g heavier.
Firmware changes:- Faster contrast AF algorithm ("drastic upgrading of algorithms")
- HDR mode now with in-camera alignment.
I wrote in my blog why there is no excuse for Pentax not to offer that and now I am proven correct. I can only hope though that K-7 receives that as an upgrade too. - Night mode which I assume is image stacking with auto align.
Would be a great feature indeed! - Focus priority or shutter priority mode for AF.S
- Focus priority or FPS priority mode for AF.C
IMHO, that is a decent replacement camera for the K-x if the revised sensor doesn't loose on its core strength: dynamic range.
Many may be disappointed that it's not a new camera (no HDMI or ext. mic port, no tilt-swivel monitor, no weather-resistant body). But it is a good revision of a camera which was one of the best selling for Pentax ever. Never change a winning strategy
And it did fix the major complain: illuminated AF points.
The improvements in the firmware are all great and I can only hope Pentax upgrades cameras in the field too. Say, after the Xmas season
