View Poll Results: What do "we" want?
Flip Screen 14923.03%
more FPS 548.35%
bigger Buffer 20331.38%
manuel Video controls 17026.28%
tethering 17226.58%
Full-Format 26240.49%
tracking AF 33251.31%
more AF-Fields 14923.03%
open-source OS/Plattform 8613.29%
Lenses >300mm in WR 13320.56%
Lens Roadmap 22935.39%
1/250th sync speed 19329.83%
150-200mm macro 6510.05%
DA*400/f4 11818.24%
Dual SDXC-Slots 14923.03%
P-TTL II with radio 10516.23%
Multiple Choice Poll. Voters: 647. You may not vote on this poll
10-12-2010, 11:59 AM   #46
Has anybody some information to this "big poll" for the lenses? i think havn't been here when it happend, maybe we can learn some things from this one.
10-12-2010, 12:44 PM   #47
privateryan's Avatar
PM Adam or a mod and ask them about it maybe? Or ask Kevin Schoenmakers since I'm 75% sure that poll was his idea but wait until he confirms that perhaps. Like I said I could be wrong about that so probably just PM Adam or a mod lol.
As far this poll goes though I voted for FF and AF everything almost exclusively with the addition of the lens roadmap. FF is really just something I want though, and the option of new and more rugged flashes wasn't in the poll.
10-12-2010, 01:07 PM   #48
I did not see DFS on your poll.
While I have four Pentax film cameras I will not buy a Pentax DSLR that forces the DFS. It's a killer for me. I recently picked up a Canon 10d to test and will most likely be in the market for a new DSLR in the spring. Pentax has till then to fix the DFS issue for me.
William
10-12-2010, 01:23 PM   #49
K(s)evin's Avatar
QuoteOriginally posted by glanglois Quote
* Auto correction spell checker for this forum. Realy. That doesn't depend on manuel changes.
I knew a Manuel Garcia once. Never met Manuel Video Control though.
10-12-2010, 01:31 PM   #50
@ Will
You dont see DFS there, because it is almost certain( everything indicates) that you will have full controll over DFS.
10-12-2010, 01:39 PM   #51
chalion's Avatar
I could use a bigger buffer and definately use a larger macro (maybe a little bit less expensive too). I added the tracking AF, more AF fields and more fps so as not to totally waste my vote.
(I actually could use a wider than 35mm macro for work, but cannot get my boss to allow the expense - cheapskate!).
10-12-2010, 05:03 PM   #52
Ratmagiclady's Avatar
This poll is phrased all about other things and conditions than ...well, much.
It didn't include the important things:
1) Available focusing screen for fast lenses and MF. Keep speeding up the AF system, but accuracy first.
2) Work out the flash system. Like, bring back true TTL and/or make cameras that'll work with other protocols. No percentage in trying to profit on a proprietary flash in a company this size, anyway
3) Uncrippled K-mount on some model or variant, and/or release more of the good old lenses in DFA skins.
Then again, when they asked this a couple of years ago, it was much the same, only I held up my K20d, and said "Screen for fast lenses!" and otherwise said, "Flash system, excellent viewfinder, and AF assist. Otherwise, put this in metal!"
They're doing OK.
10-12-2010, 05:10 PM   #53
you see, that is the difference, not many people seem to have the same opinion like you.
The flash upgrade with radio is not very often chosen and the tracking AF despite accuracy was hit pretty often
10-12-2010, 05:17 PM   #54
QuoteOriginally posted by Mehlsack Quote
Well, we don't really need a 'P-ttl 2' ...plain old (actual) TTL would be fine, if the engineering can be done. (P-ttl measures a pre-flash through the lens, not the exposure itself. It's cause of where they put the meter. I mostly use old-fashioned flash if at all, anyway, but if we're going high-tech, let's have it. )
10-12-2010, 05:39 PM   #55
I'm confused here....so far 74 people (~33%!!!) wasted a vote on a piece of PAPER? Pleeeeease, you feel adding a "Lens Roadmap" improves the Pentax line somehow? Seriously?......I mean REALLY?
now wonder so many people find it easy to take pot-shots at people using Pentax these days...
10-12-2010, 05:51 PM   #56
kevinschoenmakers's Avatar
QuoteOriginally posted by privateryan Quote
Man that's a great idea. Aren't you the one that collaborated with Adam on that poll (correct me if i'm wrong)?
Yes, correct. But you'll have to ask Adam about organising such a thing, I don't have any authority around here
10-12-2010, 06:50 PM   #57
mattdm's Avatar
I don't think we're going to have a big enough sample size to be interested, and the self-selected nature of the poll kind of unbalances the whole thing.
But that said, I do want to complain about the lack of a "fast weathersealed normal prime" option.
10-12-2010, 07:11 PM   #58
what do you mean with an uncrippled k-mount?
Since you apparently didn't even know what an uncrippled K-mount was before this thread started I don't think you could really understand how great an effect it would on metering.
Actually I totally agree with RML on all counts. Those options weren't on the poll however so I adjusted accordingly. Also see below
QuoteOriginally posted by Marcoz Quote
i would like k-mount uncrippled, at least on higher model, and availability of a split screen along with in camera support for correct metering with it (i think higher models from canon have this option).
hmmm I guess others do have the same opinion
10-12-2010, 07:15 PM   #59
QuoteOriginally posted by kevinschoenmakers Quote
I might do that, as I think the results might prove interesting.
10-12-2010, 09:25 PM   #60
uccemebug's Avatar
Couldn't think of anything I wanted from that list. My list would look like:
+ real metering for manual-focus lenses
+ manual control dials for ISO, exposure compensation and shutter speed (latter being on the PASM dial)
+ API for third-party software/hardware solutions
+ Fast 28mm lens (with aperture ring)
+ a high-quality p&s in the general S95/G12 ballpark
You know, a more interesting breakdown of interests might divide dSLR functionality from lenses and marketing efforts and so on. Also, allowing for a rated degree of interest (0 = none, the default .. 5 is urgent interest) would help. Using survs.com you can easily build such an interface. For free.
email, pentax news, pentax rumors, people, poll
Sports "Highside Exit" took 1st Place in DPReview "Missed It by THAT much, Part 1" Challenge MRRiley Post Your Photos! 27 02-21-2010 08:26 PM
K20d-Frame Count on panals..works w/"M" & "P" mode only? arbib Pentax DSLR Discussion 1 08-28-2009 05:47 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
Anyone bring "E2" fluid or the "Digital Survival Kit" on a plane? m8o Photographic Technique 2 07-31-2007 06:20 PM
All times are GMT -7. The time now is 12:44 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
