10-29-2010, 03:46 AM   #16
Col
True, could be when the EVF is switched on?
10-29-2010, 04:21 AM   #17
QuoteOriginally posted by Col Quote
And next April the viewfinder grows. Then again, maybe the update will only be valid until the end on November? Just to stimulate the market!
No, the shutterbutton will be gone, just thinking of a picture will make that happen...
10-29-2010, 05:18 AM   #18
Good news!
10-29-2010, 05:25 AM   #19
fs999's Avatar
Only at ISO 100 and PEF. Why not DNG ?
10-29-2010, 05:30 AM   #20
dgaies's Avatar
QuoteOriginally posted by fs999 Quote
It's will increase the number across the board, not just for PEF and ISO 100.
But the maximum will (likely) be at ISO 100 and PEF because that will result in the lowest file size.
At the moment, I get 8 DNG files before the buffer fills (up to ISO5000), and occasionally 9 frames at low ISO. That number drops to 4 at or above ISO 6400.
10-29-2010, 05:40 AM   #21
Continuous shooting will be improved in all sensitivities and all file formats. They just specified how many frames it is going to be at ISO100 in PEF. Expect DNG to be more or less the same.
10-29-2010, 05:56 AM   #22
ogl
Banned
QuoteOriginally posted by eurostar Quote
PENTAX K-5? ?????????????????PENTAX
If the google translator is reliable, they plan to upgrade the 8 raw buffer to 20! How they will is beyond me... unless it was hardware-planned that way and only the rush of the Photokina presentation prevented them to be able to make the camera wrks that way since the start...
It's outstanding...
K-5 18-135 kit will be launched on November, 26
10-29-2010, 05:56 AM   #23
fs999's Avatar
Thank you for the info !
10-29-2010, 06:57 AM   #24
Banned
Well I'm holding my breath, because I'm hoping to use the continu function at iso-2500 for indoor sports.
10-29-2010, 07:23 AM   #25
gazonk's Avatar
This is really good news! I don't use drive mode a lot myself, but this was the only weak point (except for lack of tethering) I could find in this camera so far.
Btw.: How fast SD cards does the K-5 need (or how fast cards can it take advantage of)? Fastest you can get?
10-29-2010, 07:25 AM   #26
I discussed the raw buffer properties with Gordon at DPR.
Here is my latest assessment after taking the firmware announcement into account:
Re: K-5 RAM size - big enough for a 20 frame buffer (RAW): Pentax SLR Talk Forum: Digital Photography Review
And this is what I said:
yes,
the new Pentax announcement indicates that Gordon's assumption was correct (full raw frames in the buffer) and that now they move to a scheme like I hinted at (compressed files in the buffer). 20 compressed RAWs are 400 MB, so, the minimum memory needed would be 512 MB much like Gordon assumed.
If the memory was 1024 MB in the first place, it is unlikely that the initial write buffer was crippled to 8 frames (256MB or 1/4 of memory) only.
If it is 512MB, then the available memory for processing (256MB initially) would now be lower (112MB) and I don't think they have been that radical in redoing their algorithms.
Therefore, I think that the memory is 512MB and the write buffer (256MB) is now used for compressed RAWs yielding 13 RAWs, not 20. If 20 isn't an error in translation (like 20% better), then they may additionally offer a 12Bit option which is also known as level compression, a rather common option elsewhere. 20 requires to store 17 (3 can be written to SD) or 15MB per RAW, corresponding to 13.7 MB for a K-7 RAW taking the #pixels into account. That's a familiar size indeed
So, that's my new guess indeed:
1. 512MB overall memory, 256MB reserved as write buffer (WB) to SD
2. FW 1.0: Partioned into 32MB 16Bit memory frames -> 8 RAWs in WB
3. FW x.x (Nov):
  • Compressed 14Bit raw files -> 15 RAWs (13 in WB, 2 written)
  • Compressed 12Bit raw files -> 20 RAWs (17 in WB, 3 written)
So, if the announcement is accurate, it implies (if my reasoning isn't flawed) that they add a 12Bit option too. It would be strange if they would only enable it in burst mode, so yeah, we may see a general level compression option (aka 12 Bit).
The good thing is Pentax is listening
The bad part is that they didn't use state-of-the-art coding in the first place
Yes, the buffer size would shrink at higher ISO. But maybe only roughly proportionally to the size increase of 12Bit raw files.
Before launch Pentax said support for SDXC would be coming via a firmware update. A quick search suggests SDXC write speeds can be theoretically as much as x4 that of SDHC.
Maybe you're over thinking things and this is all Pentax is doing?
10-29-2010, 08:24 AM   #27
QuoteOriginally posted by adamfogerty Quote
Exactly. In theory - if the hardware supports those write speeds.
It's not clear if the K-5 hardware is engineered to read/write at full SDXC speeds. Instead, it maybe the case that the K-5 will support the larger data capacities of SDXC but only read and write to them at (still pretty fast) SDHC speeds. Which if you are talking stuff like Class 10 SDHC (30MB/s or so) is still going to be a pretty decent outcome with SDXC.
10-29-2010, 08:26 AM   #28
Maybe. But maybe not...
SDXC is a feature. I expect Pentax would list this as a so in the announcement.
10-29-2010, 08:27 AM   #29
Banned
QuoteOriginally posted by Fototim Quote
SDXC was anounst for spring as I remember it. Still there are no fast SDXC cards on sale at the time.
10-29-2010, 09:07 AM   #30
Col
QuoteOriginally posted by janneman Quote
What without an 18-135mm
Sorry not to come back quicker, but I was checking the camera body to see where the second card slot was going to appear.
k-5, pentax news, pentax rumors
Un-announced firmware upgrade for K-x? Deolman Pentax SLR Lens Discussion 1 05-27-2010 03:14 PM
Cannot Update Firmware a johnson Pentax DSLR Discussion 10 04-27-2010 04:36 PM
New Canon 5D Mark II HD firmware details announced Samsungian Canon, Nikon, Sony, and Other Camera Brands 0 03-02-2010 05:22 AM
K7 Firmware Update Workingdog Pentax DSLR Discussion 2 12-22-2009 01:53 PM
Need Help to Update Firmware JamesD Pentax DSLR Discussion 22 10-20-2007 04:34 PM
All times are GMT -7. The time now is 08:36 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
