11-11-2010, 05:44 PM   #1
geauxpez's Avatar
DP Review comparison of K5, D7000 & 60D shots
Among others. Just posted -- interesting tool to play with. "Measurebators" may need new mouse batteries after this.
11-11-2010, 05:50 PM   #2
The D7000 looks like a RAW file, the 60D, looks like an over-sharpened jpeg, the K-5 looks like a heinously over-sharpened jpeg, and the 50D just like like crap.
11-11-2010, 05:52 PM   #3
Although, if you compare them as RAW, the D7000 actually looks like it is holding more detail, especially at higher ISOs, at the expense of more noise though. It looks like the K-5 is applying NR to the RAW files.
11-11-2010, 05:59 PM   #4
wow, the K5 looks much better in RAW 6400 (the most i'll probably go if i ever get one =[) vs. the D7000 RAW at 6400.
Look at the feather and the clock to the bottom right. much better i'll say.
11-11-2010, 06:19 PM   #5
geauxpez's Avatar
Don't forget -- if you're not interested in the 50D or one of the others you can change it to...say, the Nikon 300s or others.
11-11-2010, 06:22 PM   #6
To me, the K-5 images seem a little less sharp in the first place. Look at some of the small text at low ISO.
But as an untrained pixel peeper, all the images seem pretty close (minus the 50D). The D7000 and K-5 certainly have an edge at higher ISO over the 60D, but it seems small enough that'd I'd never care. I'll gladly buy an K-5 (some day).
11-11-2010, 06:25 PM   #7
JohnBee's Avatar
The K-5 low level NR is definitely showing it's effect here.
Though in its defense, I'd say that there would most likely be no issues recovering detail(minor tweak) in final output.
However, I do think Pentax should have adjusted low level NR to come-on at/or around ISO5000 rather than ISO3200. Because I don't think it's doing any good at this level.
If anything, they most likely initiated a common NR system in the K-5. However based on my own testing, the K-5 could benefit from a tweak imo.
From what I can see, the ultimate would most likely look something like this:
Low Level NR: OFF
ISO80 - ISO4000
Low Level NR 1: ON
ISO5000 - 10000
Low Level NR 2: ON
ISO12800 - 25600
Low Level NR 3: ON
... ISO51200
My 10 cents anyways...
11-11-2010, 06:32 PM   #8
QuoteOriginally posted by mikem Quote
Yea, the D7000 looks sharper in a lot of the settings.
wonder what kind of lens they're using...
11-11-2010, 07:05 PM   #9
pcarfan's Avatar
The K-5 is not generally softer, it's just that at high iso JPEG samples the K-5 has less noise and less detail (softer) due to more aggressive NR...I think the D7000 and the K-5 are a wash here.
In RAW the K-5 is much better at and above iso 3200 (Even slightly at iso 1600). At iso 12800 the K-5 is significantly better than the D7000. The iso 6400 K-5 RAW image is not really in focus though (K-5 iso 12800 samples showq more detail than the iso 6400 sample and this can't be, if not for focus issues).
11-11-2010, 07:35 PM   #10
jpzk's Avatar
https://www.pentaxforums.com/forums/pentax-dslr-discussion/121955-dpreview-ha...son-shots.html
Duplicate in another thread?
Why do we have two of the same info? ... getting annoying.
JP
11-11-2010, 07:51 PM   #11
geauxpez's Avatar
@ jpzk: Looks like the other OP and I opened threads in different forums minutes apart, both after searching for a thread on the topic. Apologies for annoying you (or anyone else), but it's bound to happen at times.
Mods, feel free to close or delete this thread if it is an unnecessary or bothersome duplicate.
Cheers,
11-11-2010, 08:03 PM   #12
JohnBee's Avatar
QuoteOriginally posted by geauxpez Quote
Cheers,
A thread merge might work
11-11-2010, 08:38 PM   #13
Posted some of this in the other thread.
They do look quite similar in JPEG. Not sure if these represent default NR settings of are they set to OFF.
IMO, the results are very close between 3 of them. Not something worth jumping ship for any one of them.
wrt JPEG at ISO12800
Its a win here loose there situation.
D7K does better with yellow, but there is a yellow cast and lots of patchy yellow blotches everywhere like what was seen on Imaging Resource. Seemly better detail on flat surface detail (eg. card prints). Then again, the contrast is slightly more as well, so that may give that extra hint of detail.
For me K5 does better with most of the other colors. Colors look a bit more vibrant. Very slightly better in fine detail for dimensional objects (Eg. feather, hair), and less noise, but can look softer on flat surface ones (eg. Printed card).
Canon 60D is not too bad overall either.
I’d actually say that all of them good enough , no real difference, win here loose there, though I’m a bit worried on the patchy yellow for D7K
If K5 is on Auto NR, then its doing itself a disservice. NR is set on MID after ISO3200 and I've found that it adds artifacts w/o doing much. In fact my own preference would be to turn off NR above ISO3200 to get the low artifact fine grain jpeg o/p that can be better worked with later with a NR program.
I am a pessimist when it comes to DPR reviewing Pentax, they will probably 'slam' the K5 against the competition as 'soft' based on the JPEG
11-12-2010, 12:15 AM   #14
It's amazing how much better the Pentax is at suppressing chroma noise in JPEG output. The D7000 and 60D are both getting slaughtered in that field, and it seems the K-5 is better than, or equal to, the other cameras in every other way, too. How the tables have turned!
11-12-2010, 12:21 AM   #15
ogl
Banned
Why do they use FA50/1.4 at F9?
pentax news, pentax rumors
60d vs d7000 vs k5 3rd party poll results opiedog Pentax K-5 & K-5 II 10 09-29-2010 10:00 PM
K5 in d300s & 7D class not d7000 tigerzen Pentax DSLR Discussion 5 09-22-2010 07:01 PM
Is there anything to these K-X comparison shots? frascati Pentax DSLR Discussion 17 02-20-2010 04:30 PM
K-7 Review on spanish Pentax forum and brands comparison cooldude14es Pentax DSLR Discussion 47 08-02-2009 05:52 AM
Comparison Macro/close-up shots valleylad Pentax SLR Lens Discussion 2 04-29-2008 10:34 AM
All times are GMT -7. The time now is 07:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
