Originally posted by Douglas_of_Sweden If this thread is open for more or less crazy ideas, I have one.
If a fixed mirror is used to reflect the picture upward to a sensor placed where the focus screen are on SLRs, the registration distance will no longer determine the camera thickness.
-Include the mirror in the SR system and correct motions with both sensor and mirror. This should help cutting down the difference between in body and in lens SR.
The less modest version (with interchangeable viewfinders) you can find on my blog.
i really like your idea! especially the
FF one on your blog, which also would work with smaller wideangle-lenses=)
(see M 20mm/4 vs. DA 21mm/3.2, which almost have the same dimensions)
*the sensor doesn't necessarily have to be at the same spot/have the same orientation as the focusing screen, you could put it nearer to the mount for example to save room behind the sensor.
I think it is optimal to maximise the yellow area in my drawing, under the condition that the sensor doesn't obstruct the light.
Or you could mount the mirror sideways and put the sensor stuff into the grip, thus saving more space for an EVF
*i've read once that the shutter should be as near as possible to the sensor to avoid diffraction at high speeds=small slit between shutter curtains. but i have no idea at what speeds/distances to sensor that effect is really relevant
*Tilting the mirror and shifting the sensor would do the same thing in terms of shake reduction, with different "side effects":
whereas shifting the sensor doesn't alter the focus plane, tilting the mirror does (as you've mentioned in your blog) As before, i have no idea how big these effects would be quantitatively, i.e. if you could even see in the photo that the focus plane was slightly tilted.
I think that, because of the lightness of the mirror and the "leverage"(move the mirror a tiny bit equals big shift of reflected light to sensor), tilting the mirror could be far more effective in SR-terms than shifting the sensor.
maybe it would make sense to implement mirror-SR only, as the current sensor-SR systems seem to add a lot of width and length to the sensor unit, which would make the whole camera bigger.
Now i hope that one day i would really have a FF-EVIL based on your idea, it is indeed very different and potentially better =)
Alex
EDIT: Originally posted by froeschle As I understood it, this thread was (at least in the beginning) supposed to be a collection of facts and ideas about the forthcoming camera
. By now, with already 11 pages, imho the main theme got a bit lost. But...
...is an interesting idea.
hmm i think there once was a thread dedicated to interesting ideas for the upcoming pentax "mirrorless" camera, maybe we should move the posts to
this thread?
